PCIE 4.0 NVMe SSD Roundup
Anvil IOPS
Published: 1st March 2020 | Source: | Price: |
Anvil IOPS
The Input/Output Operations Per Second is a popular test about which manufacturers like to brag. As you can see from the results below there is almost nothing to choose between any of the drives in any of the tests. Indeed they are all almost within test variance tolerance, with just the Sequential Write IOPS on the Viper sticking its head above the parapet.
That Corsair box just won't give up.
The blue Patriot. Does it have chips on it that say Phison per chance?
I bought two Pioneer drives and they're actually Phison which are blue.
Chances are Patriot are buying them like that.Quote
Cheers Guv, I shall watch the vid later in bed
