4x Intel 760P 1TB M.2 NVMe RAID0 Review OverKILL3D
Crystal Disk Mark 3
OverKill3D - 4x Intel 760P 1TB M.2 NVMe RAID0 Review
Crystal Disk Mark 3
There is a reason that Crystal Disk Mark has been constantly upgraded, and it's largely that it wasn't designed with the knowledge that devices with such insane bandwidth would be available so quickly. The write speeds reflect those we've seen up to now but the read speeds are definitely hampered. Let's try the latest version...
«Prev 1 2 3 4 5 6 7 8 9 Next»
09-05-2018, 13:31:32
RobM
well overkill lolQuote
09-05-2018, 13:33:43
AlienALX
Look at it. Just. Look at it !Quote
23-05-2018, 08:22:45
Shader
Hi, i am trying to get a 4x 1TB 760p vroc raid to work using the Asus Hyper X card. It only shows 1 of the 4 drives, no matter what i change. Now Intel told me, the 760p drives are not vroc compatible on x299 yet since this plattform only supports their slow datacenter SSDs, which would make the hole thing pointless. Did you not have any issues during setup?Quote
23-05-2018, 09:10:58
tinytomlogan
If youre only seeing one drive in windows its all down to BIOS settings. You 100% need an Asus X299 motherboard on the latest bios to get it all working. You even set the raid up in the BIOS.....Quote
23-05-2018, 09:38:16
Shader
I have the Asus x299 Sage mainboard and i am seeing only one drive in bios after activating vroc mode. Tried all bios versions. I am just curious that it seems to work on the rampage board used for this article when i was told the problem is that the 760p are not officially supported for vroc on the x299 plattform yet.Quote
