4x Intel 760P 1TB M.2 NVMe RAID0 Review OverKILL3D
ATTO
OverKill3D - 4x Intel 760P 1TB M.2 NVMe RAID0 Review
ATTO
For one day only we have a new graph in our ATTO results. Normally we test a selection of block sizes to give a good overview of the capabilities of the drive on test, secure in the knowledge that by the time we've hit the 1MB block size the drive wont get any faster. With the Intel 760P NVMe though it keeps on scaling up all the way until we're dealing in 64MB block sizes. The numbers we obtained were so gaudy that it would have been doing a disservice to not show them to you, whilst also demonstrating how well both the 760P and ASUS Hyper can scale as you keep adding more drives to your RAID array. Yes, that is 10GB/s you're seeing on the four drive large block read test.
«Prev 1 2 3 4 5 6 7 8 9 Next»
09-05-2018, 13:31:32
RobM
well overkill lolQuote
09-05-2018, 13:33:43
AlienALX
Look at it. Just. Look at it !Quote
23-05-2018, 08:22:45
Shader
Hi, i am trying to get a 4x 1TB 760p vroc raid to work using the Asus Hyper X card. It only shows 1 of the 4 drives, no matter what i change. Now Intel told me, the 760p drives are not vroc compatible on x299 yet since this plattform only supports their slow datacenter SSDs, which would make the hole thing pointless. Did you not have any issues during setup?Quote
23-05-2018, 09:10:58
tinytomlogan
If youre only seeing one drive in windows its all down to BIOS settings. You 100% need an Asus X299 motherboard on the latest bios to get it all working. You even set the raid up in the BIOS.....Quote
23-05-2018, 09:38:16
Shader
I have the Asus x299 Sage mainboard and i am seeing only one drive in bios after activating vroc mode. Tried all bios versions. I am just curious that it seems to work on the rampage board used for this article when i was told the problem is that the 760p are not officially supported for vroc on the x299 plattform yet.Quote
