4x Intel 760P 1TB M.2 NVMe RAID0 Review OverKILL3D
Test Setup and Up Close
OverKill3D - 4x Intel 760P 1TB M.2 NVMe RAID0 Review
Test Setup
ASUS Hyper M.2 x16
ASUS ROG Rampage VI Extreme
Intel i9 7900X
Corsair LPX 3200 - Stock Tests
Corsair Dominator Platinum ROG Edition - OC Tests
G.Skill Trident-Z 3600 - OC Tests
Corsair RM1000i
Corsair MP500 512GB
Corsair H110i GT
Windows 10
Up Close
Nobody would confuse an M.2 drive with something of enormous aesthetic beauty, but when the function is this good, the form can most definitely take a back seat. However, utilising the ASUS Hyper M.2 x16 to house them they are at least more attractive than just sitting bare in your motherboard.
If you fear that having four blisteringly quick drives in close proximity will lead to all sorts of throttling scenarios then worry no longer, as the ASUS Hyper x16 has a blower fan in place to help keep the Intel 760Ps operating at peak efficiency.
«Prev 1 2 3 4 5 6 7 8 9 Next»
09-05-2018, 13:31:32
RobM
well overkill lolQuote
09-05-2018, 13:33:43
AlienALX
Look at it. Just. Look at it !Quote
23-05-2018, 08:22:45
Shader
Hi, i am trying to get a 4x 1TB 760p vroc raid to work using the Asus Hyper X card. It only shows 1 of the 4 drives, no matter what i change. Now Intel told me, the 760p drives are not vroc compatible on x299 yet since this plattform only supports their slow datacenter SSDs, which would make the hole thing pointless. Did you not have any issues during setup?Quote
23-05-2018, 09:10:58
tinytomlogan
If youre only seeing one drive in windows its all down to BIOS settings. You 100% need an Asus X299 motherboard on the latest bios to get it all working. You even set the raid up in the BIOS.....Quote
23-05-2018, 09:38:16
Shader
I have the Asus x299 Sage mainboard and i am seeing only one drive in bios after activating vroc mode. Tried all bios versions. I am just curious that it seems to work on the rampage board used for this article when i was told the problem is that the 760p are not officially supported for vroc on the x299 plattform yet.Quote
