Just Cause 4 PC Performance Review
Testing Methodology and PC system requirements
PC System Requirements
Just Cause 4's PC system requirements are lower than Just Cause 3's at least when looking at the game's minimum hardware recommendations, lowering the minimum CPU from an Intel i5-2500K to a lower-clocked i5-2400 while the game's graphics card requirements remain similar to the game's previous iteration.
On the high-end we see things increase across the board, with the hardware listed below being roughtly what is required to play the game at 1080p maximum settings with a constant 60+ FPS framerate. Thankfully the game's settings can be scales to enable smooth gameplay on lower-end hardware.
MINIMUM:
OS: Windows 7 SP1 with Platform Update for Windows 7 (64-bit versions only)
Processor: Intel Core i5-2400 @ 3.1 GHz | AMD FX-6300 @ 3.5 GHz or better
Memory: 8 GB RAM
Graphics: NVIDIA GeForce GTX 760 (2GB VRAM or better) | AMD R9 270 (2GB VRAM or better)
DirectX: Version 11
Storage: 59 GB available space
RECOMMENDED:
OS: Windows 10 (64-bit versions only)
Processor: Intel Core i7-4770 @ 3.4 GHz | AMD Ryzen 5 1600 @ 3.2 GHz or equivalent
Memory: 16 GB RAM
Graphics: NVIDIA GeForce GTX 1070 (6GB VRAM or better) | AMD Vega 56 (6GB VRAM or better)
DirectX: Version 11
GPU Drivers
While testing Just Cause 4 we utilised game-specific drivers from both AMD and Nvidia, utilising the Radeon Software 18.12.1.1 driver and Geforce 417.22 Game Ready driver in the applicable graphics cards from each vendor.
Testing Methodology
OC3D is a website that is dedicated PC hardware, so you better believe that we test every game on a wide range of hardware configurations. This commitment to variety means that we will be using both Intel and AMD based testbeds as well as a range of GPU offerings from both Nvidia and Radeon.
Our primary test system uses Intel's X99 platform, containing an Intel Core i7 6850K at a fixed clock speed of 4GHz. This testbed will use 32GB of Corsair Vengeance DDR4 memory and will be powered and cooled by an HX1200i PSU and an H110i AIO liquid cooler respectively, with everything sitting inside a Corsair 460X chassis. In this system, we are using an ASUS Strix X99 motherboard.
Game Test Rig
Intel i7 6850K @4.0 GHz
ASUS X99 Strix
Corsair Vengeance LP 4x8GB DDR4 3200MHz
Corsair HX1200i
Corsair H110i GT
Windows 10 x64 "October 2018 Update"
Secondary Ryzen Test System
Aside from our standard X99 test system we also have a testbed based on AMD's Ryzen 7 1700X CPU, which will sit at a clock speed of 4GHz be housed in an ASUS Crosshair VI Hero motherboard. This system will use Corsair's 3200MHz Vengeance White LED memory and is contained inside another Corsair 460X chassis.
This extra system will allow us to see if any games offer a performance advantage to AMD's Ryzen or Intel's Core series processors.
AMD Ryzen Game Test Rig
AMD Ryzen 7 1700X @ 4.0GHz
ASUS X370 Crosshair VI Hero
Corsair Vengeance LED 2x8GB DDR4 3200MHz
Corsair 460X System Chassis
Corsair RMi650
Corsair H115i
Nvidia GTX 1080 Founders Edition
Rise of the Tomb Raider update - Has AMD Performance Ryzen?
GPU Selection
No gaming test suite would be complete without a selection of GPUs, which in this case covers Nvidia's GTX 10-series and 9-series and AMD's RX Vega, RX 400 and R9 300 series graphics cards. We have replaced our RX 480 GPU with its RX 580 equivalent, giving us a fairer comparison point between AMD/Nvidia's modern graphics card lineups.
Geforce GTX 10-series
- Nvidia GTX 1080 Founders Edition
- Nvidia GTX 1070 Founders Edition
- ASUS GTX 1060 Strix Gaming OC
Geforce GTX 900-series
- ASUS GTX 960 Strix
       No Man's Sky PC Performance ReviewMetal Gear Solid 5 Performance Review with ASUS
AMD RX Vega Series
- AMD RX Vega 56
AMD RX 500 Series
- AMD RX 580 Strix OC
AMD GCN GPUs
- ASUS R9 380 Strix
Far Cry 5 PC Performance ReviewMetal Gear Solid 5 Performance Review with ASUS
Keyboard & Mouse
To control this setup, we will be using Corsair Strafe RGB keyboard with Cherry MX Silent keys alongside a Corsair M65 RGB mouse, matching the general theme of this RGB illuminated system.
Cherry MX Silent Keys are ideal for gaming, coming with similar characteristics as Cherry MX Red keys, but with quieter operation. This comparative silence will help keep players immersed in their games, without the distracting clicks that are present in other Cherry key switches.
 Warhammer 40,000 Dawn of War III PC performance review  Warhammer 40,000 Dawn of War III PC performance review
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
08-12-2018, 14:09:58
AngryGoldfish
It's weird that HardwareUnboxed was seeing worse performance in JC4 over JC3. He really didn't like the way the PC port was done.Quote
09-01-2019, 05:02:03
Steven Brown
Hello folks! what PC configuration need to play this game? Does anyone guide me about itQuote
09-01-2019, 05:48:37
AlienALX
I have this maxed out and my Vega 64 runs it brilliantly. I've played for about 3 hours and it's fun.Quote
