Hellblade: Senua's Sacrifice PC Performance Review
.ini tweaks, save game location and other issues
Hellblade: Senua's Sacrifice has a few problems on PC, many of which can be fixed by editing a few game files. We typically do not look into .ini hacks in out game reviews, but Hellblade simply has to be an exception here.
Game Files Location
Hellblade's game files are located in the following directory. Here the game's save files and editable .ini files are available to view. We will go into how to edit and why you might need to edit these files below.
C:\Users\[Insert User Name here]\AppData\Local\HellbladeGame
Black Screen after changing game resolution
During our testing, Hellblade exhibited a bug where changing the game's resolution resulted in a black screen, which did not revert to our previous resolution choice in time or even after a reboot of the game and system.
This required us to look into Hellblade's game files, where we deleted the game's GameUserSettings.ini file, which contains data that hold your in-game graphical settings.
Deleting this file will force the game to reset your graphical settings and create a new file the next time the game is booted, which fixed our black screen issue.
C:\Users\[Insert User Name here]\AppData\Local\HellbladeGame\Saved\Config\WindowsNoEditor
Achieve a wider in-game FOV
FOV options are missing in Hellblade: Senua's Sacrifice, but a wider field of view can be achieved by editing the game's Engine.ini file, which is available in the same directory that is mentioned above.
Simply edit the game's Engine.ini file and add the following lines.
[/script/engine.localplayer]
AspectRatioAxisConstraint=AspectRatio_MaintainYFOV
Making a backup of your save game
While the game explicitly tells players that "all progress will be lost" is Senua dies a certain number of times, no real world evidence has been found to prove that the game has a "permadeath" mechanic.
Even so, the game only has a single save file, and some of us would like to be able to back it up or at least have a copy of the first save point to skip the game's long intro sequence if we want a second playthrough.
The game's save file is in the following location; (The Save file is called HellbladeSave_0.sav)
C:\Users\[Insert User Name here]\AppData\Local\HellbladeGame\Saved\SaveGames
Disable Chromatic Aberration and Depth of Field
Both Chromatic Aberration and Depth of Feild can be disabled using Hellblade's Engine.ini file. To disable these options simply place the following into your game's Engine.ini file. These options will also set Anisotropic Filtering to 16x.
[SystemSettings]
r.DepthOfFieldQuality=0
r.SceneColorFringeQuality=0
r.OneFrameThreadLag=0
r.MaxAnisotropy=16
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
09-08-2017, 13:57:55
NeverBackDown
Not surprising it favors Nvidia. Most Unreal Engine 4 games do because of how closely Nvidia and that engine team work togetherQuote
09-08-2017, 15:26:29
AlienALX
Bloody hell that's pretty. It looks almost too good to be true. I simply must own this game.
Ed. Reviews are glowing. Ugh, damn you crappy internet speed !
Ed2. It's only £24.99 too !Quote
09-08-2017, 16:13:47
Bartacus
The only thing keeping me away is the controls on PC. I've already heard they're awkward, game is better suited to a controller, etc. Same thing I heard about the Witcher 3 and that turned out to be bang on, so I'd be hesitant to buy this. God how I hate console ports! Too bad though, this one looks like it's EXCEPTIONALLY well done, with a great (and unique) story / setting / character.Quote
09-08-2017, 16:55:44
NeverBackDown
Witcher 3 is fine without a controller. It plays better without one. I used a controller and it was setup nice but I prefer the keyboard.Quote
09-08-2017, 17:33:41
AlienALX
If I am playing a console designed game I usually use the controller. Well, for stuff like Fallout 4 etc any way. If it's a FPS I use the KBM. IIRC I used my Xbone controller for Witcher 3 too.Quote
