Destiny 2 Beta PC Performance Review
1440p Performance
1440p Performance
Moving up to 1440p we can see that our usual 1440p test hardware continues to perform well, with only our RX 480 Strix achieving sub-60FPS minimum framerates. Every other GPU we tested was able to achieve a constant 60+ FPS, with Nvidia's GTX 1080 and 1070 GPUs achieving average framerates of over 100FPS.
Those with higher end hardware can even afford to turn up a few more graphical settings and still maintain a solid 60+ FPS framerate, which is great news for high-end PC gamers. Even so, it is difficult to tell the difference in High and highest settings outside of a side-by-side comparison, outside of factors like texture detail.
30-08-2017, 20:47:56
NeverBackDown
Well they didn't use 16 threads like they said they would. Though hitting 8 threads and still seeing performance increases is still impressive. I'm not even sure it would be worth them using more threads at this point. For Ryzen 7 in particular, with all those extra threads getting little usage, if you were to stream you would have A LOT of extra headroom for the stream and should be able to do it without much problem.Quote
31-08-2017, 05:47:17
WYP
Support for SMT is pretty broken in Destiny 2 ATM, though it could be fixed before launch. We will have to wait and see. That is the things with Beta releases, they are subject to change.Quote
31-08-2017, 11:24:03
NeverBackDown
Yeah I understand. I just think it should not be broken since they so confidently claimed they will use 16 threads. If it's broken doesn't give much hope at launch
But still not many games even use 8 cores. So it's still an achievementQuote
19-09-2017, 04:13:25
Jason Lowe
Indeed! On my Ryzen 5 and gtx 1080 the game runs at 100fps with max settings.Quote
