Elgato 4K60 Pro MK.2 HDR capture card Review
Up Close
Elgato 4K60 Pro MK.2 Review
Up Close
With their 4K60 Pro MK.2 capture card, Elgato ships everything that users should need: the capture card itself, a low-profile bracket for half-height PCIe slots an HDMI cable and an Elgato case badge.
The reasoning behind this bundle is simple. Most consoles and high-end TVs already ship with an HDMI cable, which means that users of this card are almost guaranteed to have at least one HDMI cable. By providing an HDMI cable, Elgato ensures that users of this card have two quality HDMI cables, and aside from this users need little else.
No driver CD or USB is included here, but for a good reason. When the aim of the game is streaming and content creation, it is hard to see any use of this capture card lacking internet access.
Perhaps the only downside of the 4K60 Pro MK.2, when compared to its predecessor, is its lack of a full-cover backplate. Cooling-wise, the 4K60 Pro MK.2 doesn't need it, but aesthetically it's hard to argue with having a backplate.
While this isn't a problem, we can see this aesthetic choice annoying a small sub-section of the PC gaming community. That said, those people could always try making their own.
With the 4K60 Pro MK.2, Corsair has enabled 4K 60FPS HDR capture within small form factor PCs that use half-height PCIe brackets. This is great news for fans of small form factor secondary systems. This also presents the 4K60 Pr MK.2 as an ideal upgrade option for users of the original HD60 Pro internal capture card.
With the unit comes a 1.5m long HDMI cable. While a longer cable would be preferable for some use cases, this length is more than adequate for most setups. Ideally, this PC will be sitting very close to the user's console or gaming PC, so a 1.5m cable is more than enough. Some users will prefer shorter cables and others will prefer longer ones. 1.5m is a good compromise solution.
The Elgato 4K60 Poro requires a PCIe x4 slot to operate, making the card usable within a wide range of modern PC systems. On our Ryzen-based test system, we slotted the card in our secondary PCIe 3.0 16x slot, which is wired for electrically for up to PCIe 3.0 x8 speeds.
With the 4K60 Pro MK.2, Elgato has opted for a subtle appearance, avoiding RGB and other unnecessary complexities. The capture card is dark and clean, which means that it will fit in well with most modern systems.
Elgato's use of an all-black PCIe bracket allows the unit to match most modern PC cases. The Elgato logo on the high-profile bracket allows users to see which PCIe card is their Elgato capture card easily. Elgato also clearly labels the unit's HDMI in and out ports.
«Prev 1 2 3 4 5 Next»
29-08-2019, 04:39:34
ET3D
Thanks for another good article.
What bothers me about these new RT games is that much of this could be implemented reasonably simply without RT. Reflections from planar surfaces is something which has been done from the dawn of rasterised 3D graphics. Just adding this would remove most of the wow factor that RT has.
What NVIDIA has done is basically to incentivise game devs to cripple their games in order for RT to look more impressive. Unfortunately, it seems to be working.Quote
29-08-2019, 09:39:08
tgrech
[Edit]Quote
29-08-2019, 09:55:24
WYP
Can we move the Control Raytracing stuff to the proper thread? Raytracing has nothing to do with the Elgato 4K 60 Pro.
https://forum.overclock3d.net/showthread.php?t=92938Quote
29-08-2019, 17:56:41
Stoly
Screen Space reflexions can only do so much as you can clearly see in the screenshots.Quote
03-09-2019, 12:47:00
Ishimuro
Holy Cow. To be honest the thing wich looks most amazing to me is the Grey... Box? On the table in the first comparison Screenshot. How lifeless it looks without RTX and how the colorcast of the Table helps blend it in the Scene. Guess it's like VFX: The best ones are the ones you don't notice as those.
Maybe in a few years I will shell out the money for a Raytracer.Quote
