Kingston HyperX Savage DDR3 2400MHz 16GB Kit Review
Kingston are one of the biggest names in the memory industry, with a kit available regardless of the size, speed and even aesthetic requirements you have.
Their HyperX brand has always been the provider of some very fast options, as well as coming equipped with some of the best looking heatspreaders around.
The Savage kit we have up for review today ticks both of those boxes, with 16GB of 2400MHz goodness wrapped up in one of the coolest designs we've seen for a while.
Let's take a closer look.
Fast : top-performing modules available with low-profile heat spreader
Unique : red, asymmetrical heat spreader sets new trends for PC builds
Quality : aluminium die-cast heat spreader with a diamond cut finish
Design : low profile to fit under oversized CPU coolers
Reliable : 100-percent factory tested
Guaranteed : lifetime warranty, free technical support
Capacity : 8GB-32GB (kits)
Frequency Speed : 1600MHz, 1866MHz, 2133MHz and 2400MHz
CAS Latency : CL9-CL11
Voltage : 1.5V, 1.65V
Operating Temperature : 0°C to 85°C
Dimensions : 133.35mm x 32.8mm
Compatible : H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel and A75, A87, A88, A89, A78 and E35 AMD chipsets
Warranty: Lifetime
In our Z97 test rig the Savage easily hits its XMP. Despite the timings being a little slacker than we'd like at this price it's difficult to complain.
«Prev 1 2 3 4 5 6 Next»
15-12-2014, 18:07:55
Thelosouvlakia
N00b question, will those work with the 990FX chipset (provided that the board supports 2400Mhz DRAM speeds)?Quote
15-12-2014, 20:00:34
Boinkjumper
Hmm, it might only seem to support the following chipsets: H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets
as well as A75, A87, A88, A89, A78 and E35 AMD chipsetsQuote
15-12-2014, 20:20:06
NeverBackDown
You could easily google it and look at the compatibility list on the website...Quote
16-12-2014, 00:05:18
realneil
Great looking RAM, and as said in the review, the HyperX name means that it's good stuff. (worth the small price premium)Quote
16-12-2014, 11:42:02
Thelosouvlakia
Asus hasn't updated their Memory compatibility lists for those motherboards, neither Kingston has included the chipsets to the tests.. However if it supports E51 chipset, 990fx shouldn't be a problem, idkQuote
