Corsair K95 RGB Platinum XT Review
Software
Software
The iCUE and Stream Deck software packages are where the meat of the XT updates are to be found. If you've spent any time using the iCUE software a lot of this will be familiar but we'll go over it nonetheless. The lighting is handled by layers, allowing you to create anything your imagination can consider. As well as plenty of presets there are a whole host of triggers you can play with, and even the light bar is customisable with its 19 different LEDs.
The macro editor is equally powerful, whether you want a simple key combination or a timing and profile based trigger system. Like the lighting the only limits are your imagination and time.
Like the lighting there are a bunch of preset actions built in giving you full control over everything from the simple to the mind-boggling.
As with any newly launched product the firmware updates should be checked regularly, although we have to say that even in its pre-release form we didn't spot any flaws or things that didn't work as they ought. Typical Corsair reliability.
The main change is the addition of cross compatibility with the Elgato Stream Deck. With the latest software installed for both applications you can choose G-Keys - the six keys on the left of the K95 - as Stream Deck keys and customise them with all the features you find within the main Stream Deck application.
As the keyboard doesn't have a display like the Stream Deck does it might be easy to forget what is what so there is a fly-out box that shows the logos for each action. For the purposes of this screenshot I've moved it over the action box in the iCUE software but you can place it anywhere you like on your desktop, on any monitor, or even just hide it if you'd prefer. The Stream Deck logo at the bottom of the tower takes you straight to the software too.
«Prev 1 2 3 4 5 6 Next»
06-01-2020, 14:09:33
m2geek
Is it just me, or are corsair keyboards getting uglier and more "gamergrotesk" whereas Razer and the like are growing up and maturing in their design?
Blergh...Quote
08-01-2020, 07:33:30
demonking
Blergh...
Its not just their keyboardsQuote
11-01-2020, 21:30:57
Digikid
Blergh...
I would argue the complete opposite. Corsair knows good design and sticks with it. It benefits them that they don't have to resort to "gimmicks" like Razer does.
Plus I would take the QUALITY of Corsair over Razer junk ANY DAY. I have had loads of friends rant and rave about Razer.....only to go to Corsair a few months later dues to their Razer junk failing on them.
I myself have a K70 LUX RGB that I have had since it came out....with absolutely no issues whatsoever.
As todays kids say....YMMV.Quote
12-01-2020, 08:41:10
trawetSluaP
That's a five year old keyboard, I think these guys are referring to their newer line-ups.
I had a K70 that was very good, really well built and only got replaced cos one my cats puked on it Quote
