Corsair K95 Platinum Speed Review
Up Close
Up Close
The Corsair Gaming packaging has always been attention grabbing thanks to the yellow flashes that differentiate it from the world of all black with a tiny bit of red peripherals that have come to dominate the packaging market. A quick perusal of the reverse side shows how much Corsair have squeezed onto the K95 Platinum. Programmable macro keys, per key lighting, onboard profiles, dedicated media keys. If it has ever appeared on a mechanical gaming keyboard then it is to be found here on the K95 Platinum. Inside the box Corsair have provided a proper wrist rest with a reversible rubber portion. It's not as comforting as a gel wrist rest is, but it's a darn good wrist rest given the hard plastic that usually gets included with keyboards. Corsair have also included a set of curved and textured keys for those of you more likely to game than type with the K95 Platinum. The textured space bar takes a little getting used to, but otherwise wherever you look you find quality - from the six macro keys on the left hand side to the all metal volume wheel on the right. It's a product that feels just as high-end as it looks. The braided cable alone, with its tight but soft feel braid and extremely thick dimensions should clue you in to what to expect from this upgraded K95.
«Prev 1 2 3 4 5 Next»
06-02-2017, 16:54:41
RobM
I really miss my K95 having had LED issues and only able to accept the smaller 65 im struggling to get used to not having the number pad.Quote
06-02-2017, 20:01:52
Dark NighT
Have to say, those media buttons are UGLY, and that volume wheel being a bit more away from the edge, suppose could get used to, but it was prettymuch perfect where it was on the older models.Quote
07-02-2017, 11:48:00
demonking
I've had the same problem with my chroma tournament.
It's a shame that they didn't go with white Base under the keys. It made a he'll of a difference on the k70.Quote
09-02-2017, 20:36:35
Doomslayer
Pass.....Corsair have had way too many issues with their RGB's keyboards.Quote
