Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Preview
Up Close
Up Close
The Gigabyte Aorus range has always had attention grabbing packaging and the Waterforce RTX is no exception. For a start the box is huge, having to contain both one of the bigger cards on the market and a dual width radiator. It's more the size you'd expect to get from a EATX motherboard package. Opening it is definitely an event as the box lid lifts to reveal a card that looks attractive even without the lighting.
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Packaging
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Internals
Free from the high density foam that protects the Aorus Extreme Waterforce on its way to you, the card is revealed in all its glory. A clear window allows you to see the waterblock whilst also providing a platform for Gigabyte's RGB lighting to do its thing. Definitely a product you want to install when your chassis is on its back rather than stood up.
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Card Overview
Although parts of the lighting are on the side you don't see unless your tower is way above you on a shelf, the backplate is very attractively sporting the Aorus logo whilst also helping reinforce the PCB and spread what little heat is generated across the whole width of the card.
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Backplate
The fans are full RGB offerings ensuring that both the top and bottom portions of your case are bathed in your hue of choice, whilst a dual width radiator guarantees that even the most hardcore overclocker shouldn't reach thermal saturation. We often see AIO GPUs come with just a 120mm radiator, and whilst the RTX 2080Ti isn't the hottest card Nvidia have ever released it's nice to know Gigabyte have given you plenty of thermal headroom. Not only useful for overclocking fun and games but if you run it at 'stock' spec then it should let you slow the fans down a little for even quieter gaming.
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Radiator
With any AIO the hose quality is a key element. You don't want all that liquid suddenly appearing where it isn't wanted. With the Gigabyte RTX 2080Ti Aorus Extreme Waterforce the cables have a very tight braid on them, whilst the fan cables are pre-attached. It's hardly any more complicated to install than a regular air-cooled graphics card, and that will win a lot of friends amongst the first timer installers.
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Hoses
At the business ends of the RTX 2080Ti Aorus Extreme we have the 8+8 pin PCIe power inputs, as well as a whole host of display output choices via the three DisplayPort, erm, ports and the three HDMIs. There is even a VirtualLink USB Type-C should you require it.
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Power Requirements
Gigabyte RTX 2080Ti Aorus Extreme Waterforce 11G Display Outputs
«Prev 1 2 3 Next»
03-05-2019, 08:36:29
Warchild
RGB Fans unite!
Bad spellers Untie!Quote
03-05-2019, 10:12:17
Dicehunter
That looks like something Megatron would use Quote
04-05-2019, 12:02:25
Warchild
Even the logo Quote
04-05-2019, 19:14:40
Avet
https://i.imgur.com/bbotzZ2.jpgQuote
