Corsair Hydro GFX GTX 1080 Ti Review
Test Setup and Clock Speeds
Test Setup
Intel i7 6850K
ASUS X99 Strix
Corsair ROG Dominator Platinum 3200
Corsair RM1000i
Corsair LX 512GB OS
Corsair LS 480GB x2 Raid0 Games
Corsair H100i V2
Windows 10
Clock Speeds
With everything set to defaults the Hydro GFX is only bettered by the full water cooling on the ASUS Poseidon. The big benefit of the Corsair Hydro GFX though is the ability to balance the fan to find the best compromise between noise level and cooling capacity, so on the next page we'll see how fan speed affects things. The "default" settings will be the ones we use for our testing though.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
14-06-2017, 12:23:15
Greenback
A question could you swap out the 120 AIO with a 240 considering it's probably only an asetek AIO, maybe something like the kraken x61, H105 or H110 which have a round pumpQuote
14-06-2017, 12:42:32
tinytomlogan
The fittings that come out of the pump on this are straight out of the side, the aftermarket CPU coolers come out of the sides at a 90 degree angle (away from mobo) or out of the top of the pump (again away from mobo)
So swapping out would require a lot more than just changing the cooler. You'd need to mod the cover and also need a fair bit of hose to route anywhere tidyQuote
14-06-2017, 13:15:54
Tolemac
Nice review Tom as always but is it worth going WC from air with Pascal?Quote
14-06-2017, 13:17:38
tinytomlogan
Depends what your temps are like tbh fella?Quote
14-06-2017, 13:20:43
Tolemac
I'm hitting 71C on air Palit GTX 1080 Jetstream whilst benchingQuote
