Corsair Hydro GFX GTX 1080 Ti Review
Up Close
Up Close
It's a slightly curious situation with the Corsair GFX in that there isn't much to explain because it looks exactly like you would expect it to. It's a graphics card, with an AIO bolted onto it. The backplate looks very good and the all important tubes between the card and the cooler are all you could desire, being lengthy, flexible but robust and with some seriously quality braiding to ensure that everything remains in perfect working order. If there is an area of mild disappointment it is the choice of shroud. Without requiring the fans that you see on MSI Twin Frozr VI cards, Corsair were free to let their artistic team run wild and we ended up with something very bland. Maybe the way that the cooler is inside means that you have to have the water-wheel fan running to keep the power phases cool. Still, it's all fairly stock looking which is a bit disappointing at this price point. The shroud doesn't do much, go wild designer people.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
14-06-2017, 12:23:15
Greenback
A question could you swap out the 120 AIO with a 240 considering it's probably only an asetek AIO, maybe something like the kraken x61, H105 or H110 which have a round pumpQuote
14-06-2017, 12:42:32
tinytomlogan
The fittings that come out of the pump on this are straight out of the side, the aftermarket CPU coolers come out of the sides at a 90 degree angle (away from mobo) or out of the top of the pump (again away from mobo)
So swapping out would require a lot more than just changing the cooler. You'd need to mod the cover and also need a fair bit of hose to route anywhere tidyQuote
14-06-2017, 13:15:54
Tolemac
Nice review Tom as always but is it worth going WC from air with Pascal?Quote
14-06-2017, 13:17:38
tinytomlogan
Depends what your temps are like tbh fella?Quote
14-06-2017, 13:20:43
Tolemac
I'm hitting 71C on air Palit GTX 1080 Jetstream whilst benchingQuote
