ASUS ROG Strix RTX 2060 Review
Middle Earth : Shadow of War
Published: 14th January 2019 | Source: ASUS | Price: £449 |
The important settings here are no dynamic resolution and everything else on Ultra. As it supports it you’ll also find us using heavy doses of Temporal Anti-Aliasing, to really make the most of Middle Earth.
With just enough performance at stock to out-do a stock GTX 1080, and a good performance boost to be found if you go the extra mile and overclock it hard, the Strix is a great choice for Shadow Of War.
It's impressive but I fail to see a reason to buy this over an entry level 2070 or just 2060 FE, which certainly has an adequate cooler.
So, same price as the card that's a level up ? The only award it should win is mugs choice.
