MSI B450 Gaming Pro Carbon AC Review
3D Mark
3D Mark
3D Mark is all about trying to spot a chink in the armour and the B450 has no chinks at all in it. Nothing but smooth well-fitting armour guaranteed to reflect polearms. That's stretched that metaphor about as far as it can go.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Next»
23-08-2018, 09:39:27
AlienALX
That's quite nice that. Almost like B350 Strix "I am cheap but I look expensive" nice.
I don't bother with wishlists though. I usually make them, then end up buying it all by the time the day is out lmao.Quote
23-08-2018, 13:35:36
Darkdayzzz
Just as a "warning" so to speak - when you use a M.2 NVME drive it disables 2 of the SATA ports from functioning. This applies each time you use another M.2 slot, atleast it does on the AsRock build I just made for my work.
Dual Samsung 970 NVMEs in Raid 1 and it causes me to lose 4 SATA connections. Which left me with 4 available SATA slots since the motherboard had 8 to start with. This would have happened regardless of RAID or not.
This is just a warning as I said since if I used both M.2 slots on this MSI board I'd not have enough room SATA plug wise to get all the HDDs in place due to the M.2 use disabling one set (2) SATA slots each.
Again, this is on my ASRock board for the build at work, I don't know if this affects all boards that have M.2 slots... just trying to help with this info is all :PQuote
23-08-2018, 22:47:19
NickOmega
Actually looked through this one quite intently because I have this mobo sat on my desk waiting for me to get around to building; Just need vendors/nvidia to stop with the rip-off prices for 2 year old GPUs
This is the block diagram from the user guide.
https://i.imgur.com/FGyPNp3.jpg
and in the specification:
PCI_E2, PCI_E3, PCI_E4 and PCI_E5 slots will be unavailable when installing M.2 PCIe SSD in M2_2 slot.
SATA5 and SATA6 ports will be unavailable when installing a M.2 device in M2_1 slot.
M2_1 is the upper port, M2_2 is the lowerQuote
