Intel Core i9 10980XE and ASUS ROG Rampage VI Extreme Encore Review
Cinebench R20
Cinebench R20
The latest version of Maxon’s rendering engine tests both single core performance as well as the multi-threaded option, dispensing with the OpenGL rendering test we had in the earlier version.
The better turbo ability of the latest 10th Generation XE CPU makes its presence felt in our stock test where the processor is overclocking itself, whilst the overclock sits somewhere between the Core i9-7980XE and Threadripper 2990WX. There isn't much to choose between the X299 motherboards, as it should be.
Intel Core i9-10980XE and ASUS ROG Rampage VI Extreme Encore Cinebench R20
Intel Core i9-10980XE and ASUS ROG Rampage VI Extreme Encore Review
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Next»
25-11-2019, 09:38:09
tgrech
Oh my, these HEDT releases are like the local busses, nothing for ages then a load appear all at once, looking forward to digging into these articles soonQuote
25-11-2019, 09:46:42
Warchild
Its funny that intel brought the embargo forward 6 hours to avoid the AMD launch.Quote
25-11-2019, 09:53:32
FTLN
Can it be delidded ?Quote
25-11-2019, 18:09:04
Avet
Theoretically yes if it is like 9980XE. It is really tricky. But you really need to know what you are doing and be very, very careful. And also i wouldn't recommend it on a regular chip. Only on pre-binned ones, with direct die mount, and ballsy water cooling setup.Quote
25-11-2019, 18:21:55
AlienALX
We can see why now.Quote
