ASUS ROG Strix X470i Gaming Review
HEVC
ASUS ROG Strix X470-I Gaming Review
HEVC
The Strix X470-i brackets our HEVC graph. Once again it shows itself to be the kind of motherboard that is best when you really wring it out and is nothing much to write home about in regular trim.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
30-05-2018, 15:39:47
XPredator
Tom, any news on x470 crossahair extreme?Quote
30-05-2018, 16:18:32
g0ggles1994
That won't be for a while yet. The VI Extreme got announced at the end of July last year so a VII Extreme would probably be around the same time-frame. Although I maintain that having it ready for the CPU launch would have sold very well.
TTL, What kind of error did Gears give when you tried running it? Bit weird that it just flat out refused to run at allQuote
30-05-2018, 19:17:02
flowerdealer
Got this board and tried two m.2 drives on the main front slot, and they didn't work. The slot doesn't even appear in the BIOS. Returned it and got an different board instead.Quote
31-05-2018, 05:03:38
AlienALX
Originally Posted by flowerdealer View Post
Got this board and tried two m.2 drives on the main front slot, and they didn't work. The slot doesn't even appear in the BIOS. Returned it and got an Asrock board instead.
IT would depend on your drive/s and whether you have it set to the right mode. There are two different types of M.2. One is SATA and will need to be set accordingly and the other is NVME which uses PCIE lanes. Usually when you use SATA it knocks out a couple of your SATA ports on the board. However, I would imagine PCIE/NVME needs the controller to be enabled.
Silly question but did you read the manual?Quote
31-05-2018, 06:33:53
tinytomlogan
That does sound like user error tbh.Quote
