ASUS ROG Strix X470i Gaming Review
Test Setup and Overclocking
ASUS ROG Strix X470-I Gaming Review
Test Setup
ASUS ROG Strix X470-i Gaming
AMD Ryzen 7 2700X
Corsair LPX 2666MHz
Corsair LPX 3200MHz
Corsair MP500 M.2
nVidia GTX 980
Corsair HX1000i
Corsair H110i GT
Corsair ML Fans
Overclocking
As always with our overclocking we have two types. At the top is the overclock which we'll be using for our tests. Given the robust nature of our benchmark suite it is always more demanding than the kind of overclock you might be able to obtain if simply glory hunting. However, if you are in the mood to just look for impressive screenshots then the Strix ITX is more than capable as you can see from the bottom CPUz. If you ever doubt how much ITX motherboards have improved in recent years, and how great this 2nd Generation Zen architecture is, hopefully this dispels those qualms.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
30-05-2018, 15:39:47
XPredator
Tom, any news on x470 crossahair extreme?Quote
30-05-2018, 16:18:32
g0ggles1994
That won't be for a while yet. The VI Extreme got announced at the end of July last year so a VII Extreme would probably be around the same time-frame. Although I maintain that having it ready for the CPU launch would have sold very well.
TTL, What kind of error did Gears give when you tried running it? Bit weird that it just flat out refused to run at allQuote
30-05-2018, 19:17:02
flowerdealer
Got this board and tried two m.2 drives on the main front slot, and they didn't work. The slot doesn't even appear in the BIOS. Returned it and got an different board instead.Quote
31-05-2018, 05:03:38
AlienALX
Originally Posted by flowerdealer View Post
Got this board and tried two m.2 drives on the main front slot, and they didn't work. The slot doesn't even appear in the BIOS. Returned it and got an Asrock board instead.
IT would depend on your drive/s and whether you have it set to the right mode. There are two different types of M.2. One is SATA and will need to be set accordingly and the other is NVME which uses PCIE lanes. Usually when you use SATA it knocks out a couple of your SATA ports on the board. However, I would imagine PCIE/NVME needs the controller to be enabled.
Silly question but did you read the manual?Quote
31-05-2018, 06:33:53
tinytomlogan
That does sound like user error tbh.Quote
