ASUS ROG Rampage VI Apex Review
Up Close
Up Close
There is a minor change to regular ASUS ROG packaging with the Rampage VI Apex. Instead of the all-red with silver text we're used to there is now a black quartering reminiscent of the Crosshair VI you can see in the background. Is this a step towards a wholesale change in ASUS ROG packaging design or just a chance to go for something other than all red everything? Time will tell.
You would expect a motherboard that requires such a significant investment to come with every possible accessory the motherboard world has to offer and it most certainly does. There are cables and bridges and stickers and manuals and all manner of elements to add value to your purchase.
The PCB for the Rampage VI Apex is the first thing we noticed. That massive cutaway by the SATA ports and the lesser cutaway by the SupremeFX audio are attention grabbing if nothing else. We also think it's a brave decision to remove some real estate on a chipset that already is extremely space intensive and that is before we include all the ASUS specific features. The other element which catches the eye is how the Rampage VI Apex doesn't go with 8 DIMM slots as we usually find on X299 motherboards, but instead has converted two of them into low latency, high bandwidth storage connectors. Given that we can't recall ever seeing a rig that utilised all eight slots it isn't too much of a compromise.
With so many cores available to play with, cooling is the single most important part of the latest Intel chipsets and CPUs. Cooling has always been vital to producing either better overclocking or adding longevity to your hardware, but the Kabylake-X products require massive amounts of cooling to run at their full effectiveness and it's very easy to get them thermally throttled. To this end the Rampage VI Apex has fan and pump headers everywhere you look. Even those of you with seriously high-end custom watercooling shouldn't find themselves running out of headers to connect their fans and pumps to.
VRM temperatures have been another hot button issue and the Rampage VI Extreme seeks to solve this with the implementation of a fantastically sculpted piece of alloy connected via a thick heatpipe to a further heatsink at the rear of the board. We look forward to finding out how successful this has been at taming the X299 VRM temps.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Next»
27-08-2017, 18:05:53
Avet
This board is perfect to utilize that external water cooling kit you have Tom. But i think you wouldn't mind setting up some proper loop to test this bad boy. Too bad you can't test it with delidded CPU.
I like they consulted overclockers in designing this board. I am surprised you didn't give it ultimate reward like to the Maximus IX Apex.Quote
28-08-2017, 01:22:48
Kaapstad
I am still laughing at that !!!!
There is a bad fault with this board and all the Rampage boards for that matter if you are using 4 cards. All the connectors at the bottom of the board are covered by the 4th card which makes them useless. This could have been overcome by turning the connectors 90 degrees like they have done with the molex connector found on Rampage boards.
Also having the connectors turned 90 degrees would make cable management even easier.Quote
28-08-2017, 04:45:01
AlienALX
£419. Why does that sound like terrific value for money?
Stunning isn't it? Asus at the top of their game. They really are. I also like how they continue those looks all the way down to the bottom now too (B350 Strix).Quote
28-08-2017, 16:39:49
JLR
Great review, love the board. The way the bottom is off cut and the access to the SATA ports is great. As Tom said it looks like the board is capable of giving more if you have a de-lidded CPU.
28:07 in the video has buckled me, had a mouthful of Pepsi at the time and my Monitor / Keyboard nearly had it second hand .Quote
