AMD Ryzen Retest 1500x 1600x 1800x Review
CineBench R15
AMD Ryzen Retest Review
Cinebench R15
This is starting to become a trend. If there is a benefit to be found it's usually in the older CPU's because of the 100MHz faster overclock. However, the improved memory coupled to the same overclock of the 1800X gives it a bump ahead of the original test. In single thread performance though the newer BIOS definitely has the edge, albeit by a tiny sliver.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Next»
21-07-2017, 10:13:40
GiantKiwi
And yet even on that BIOS i'm having to RMA my stuff again. USB controller's gone completely bananas, often refusing to recognise any devices past the first 30 minutes of the machine being switch on, i've never got any QVL memory kit to clock at all on this motherboard, regardless of whether they're hynix or samsung based or either an even/odd CAS. I'd say it's luck of the draw as i've had 6 of this motherboard, none working as described.Quote
21-07-2017, 11:38:36
RyzenMaster
So, these benches confuse me. Why am I getting similar or higher scores with my 1700 @ 3.875 GHZ and Mem @ 3066mhz? Not complaining about your review, mind you, I'm just curious.
Thanks for the quality review. You're the Best TTLQuote
21-07-2017, 12:50:13
MacLeod
Thanks for the review. Not many re-test articles out there. Interesting results too. Lots of people were saying immature BIOS is what was holding Ryzen back for a while. I was one that was kinda hoping that was true so the gaming performance would improve some but glad to know Ryzen is what it is.Quote
21-07-2017, 13:28:51
NeverBackDown
It did improve. Don't take these results as definitive. It's only 3 games. Not saying his are wrong but you'd have to test a bunch to get an answer. I'm sure it's nothing drastic but improvements all around are there. Should check WYP article on his recent memory tests. You see pretty noticeable gains.Quote
21-07-2017, 13:49:17
AngryGoldfish
Thanks a lot for taking the time to retest these.Quote
