AMD Ryzen 7 2700X with Corsair H60 Overclocking & Undervolting
Regular Overclocking Methodology
AMD Ryzen 7 2700X Overclocking/Undervolting
If you go down the standard overclocking idea of just adding more volts and hoping that your cooling can cope, it is possible to squeeze 4.2 GHz from the Ryzen 7 2700X. Nobody wants to stuff 1.4v through their CPU 24/7 though, so instead let's set the system up to run all the cores at a static speed, rather than boosting up and down all the time. That way we can attain a more stable platform and it lets us go lower on the volts than we could if we let the BIOS fiddle with the clock speed as necessary, whilst doing so at a more manageable voltage.
Straight away the shift from boosting to stable clock speeds allows us to drop from the factory stock setting of just a hair over 1.4 volts on the VCore down to 1.3v. It's a good start, but here at OC3D we're not interested in good starts or doing the bare minimum. It also seems unfair on the Ryzen 7 2700X to not give it a fair crack of the whip and a chance to show what it can really do.
«Prev 1 2 3 4 5 6 7 Next»
26-06-2018, 16:18:20
Ishimuro
"nobody wants to put 1.4V 24/7..."
*Looks at his 1700, whispering: "I'm so sorry buddy, bare with me"*
But damn i wanted 3.9 so badly. I guess... well. Maybe. Mhh. You made me think. Maybe I'll tinker with it a bit more and see how far 1.3 will get me xDQuote
26-06-2018, 19:58:13
NeverBackDown
1.4v is safe for Ryzen. AMD recommends no more than 1.45v for extended periods. So personally 1.4v is the max I would go.
As for the article it's crazy to see how that bump from the optimized 4ghz to the 4.2ghz max clock changes temps and power draw. Definitely not worth 200mhz..Quote
30-06-2018, 16:08:24
NickOmega
I've been looking at the x470 Prime for a 2700X build, and the heatsinks don't fill me with confidence. How were VRM temps during testing?Quote
30-06-2018, 19:05:31
NeverBackDown
You should be fine honestly. Unless you are maxing out the CPU on a OC you'll be alright.Quote
