SilverStone Kublai KL05 Review
The Kublai KL05 from Silverstone is available as both a Quiet version, with a solid side panel and front panel, and as the Windowed version with a mesh front grill that we have here review today.  Measuring 535mm in height it's a little taller than most mid towers, but rest assured there's a very good reason for that.  Take a closer look at the case and you'll spot that the roof panel is somewhat elevated.  It doesn't take a genius to work out that as a result of this lift, the KL05 can take decent sized rads up in the roof.  But that's not where the water cooling options end.  if you want to know more you're going to have to read on, starting with the Technical Specification.
 Material Steel and Plastic
 Dimensions 525x200x494mm (HxWxD)
 Motherboard ATX, M-ATX
 5.25" 2
 3.5" 6
 2.5" 8 (six shared with 3.5")
 Expansion Slots 8
 Front I/O USB3.0 x 3, HD Audio
 Air Cooling
 Front: 2x120/140mm (1x120mm included)
 Roof:  2x120/140mm
 Rear:  1x120mm
 Base:  2x120mm
 Water Cooling
 Front:  Up to 1x240mm
 Roof:   Up To 1x240/280mm
 Rear:   1x120mm
 Max CPU Cooler Height 165mm
 Max GPU Length 400mm
 Max PSU length 225mm
 Weight 6.9kg
«Prev 1 2 3 4 5 6 7 8 Next»
06-10-2015, 22:37:21
realneil
Good case with decent options for cooling.
I like the fact that it has 5 1/4" bays on the front. For me, this is necessary.
The price is pretty good too.Quote
06-10-2015, 23:02:57
Dicehunter
You excite a man with the possibility of an OC3D video only for those dreams to be squashed and thrown away.
Wii needz moar viddeoz
Good written review though Quote
07-10-2015, 05:16:16
Feronix
It just looks so odd to me with that small window and the tall roof. I don't think I could have this on my desk without being annoyed by that on a daily basis.Quote
07-10-2015, 10:29:05
Kilbane
I can second that, it just looks uninspiring.Quote
