Raijintek Paean Review
We’ve seen some pretty nice stuff from Raijintek recently, to the point where we’re pretty much going to forget about the odd quality issue they had when they first came on the scene.  So what’s the Paean all about?  Well, although a not entirely new concept, it is fairly rare to see an open frame architecture case that combines 4mm thick hair silk anodised Aluminium, with 5mm thick tempered glass panels.  To bring us this stunning aesthetic Raijintek have had to make a few concessions, let’s hope they haven’t ventured too far in the direction of form over function.  To give us a bit of an inkling as to how things stack up, let’s have a look at that all important Tech spec shall we.
Technical Specification
Dimensions 286x587x417mm
Weight 12.8kg
Material 4mm Aluminium, 5mm Tempered Glass
Motherboard support ATX, M-ATX, M-ITX
3.5″ 3
2.5″ 3 (shared with 3.5″)
Expansion slots 8
Front I/O 4xUSB3.0, HD Audio
Air Cooling 3x120mm, 2x140mm
Water Cooling up to 280mm, 360mm
Max CPU Cooler Height 140mm
Max GPU Length 310mm
Max PSU Length 200mm
 Â
