NZXT S340 Elite Review
It’s been a while since we took a good look at an NZXT case, so what better place to start than the new S340 Elite. It’s available in White, Black and Red, and the Matte Black version we have for review And when I say black, I mean it’s BLACK, or as Ford Prefect would put it, “I mean it’s so black! You can hardly even make out its shape. Light just falls into it”. Hitch-Hikers references aside, the Elite really is a stunning looking case, and it has a few tricks up it’s sleeve to boot. For the low down let’s have a look at those all important Tech-Specs shall we.
| Dimensions | 474x203x432mm (HxWxD) |
| Material | Steel Chassis and exterior panels, Tempered Glass Panel, some ABS Plastic internally |
| Motherboard Support | ATX, M-ITX, M-ATX |
| 3.5″ | 2+1 |
| 2.5″ | 3+1 |
| Expansion slots | 7 |
| Air Cooling |
Front: 2x120mm/240mm Top: 1x120mm/140mm (1x120mm Included) Rear 1x120mm (1x120mm included) |
| Water Cooling |
Front: Up to 240mm/280mm Rear: Up to 120mm |
| Front I/O | HD Audio, 2xUSB3.0, 2xUSB2.0, HDMI with VR Support |
| Weight | 8.13kg |
| GPU Clearance | 364mm (334 with radiator) |
| CPU Cooler Clearance | 161mm |
Key Features
Steel chassis and tempered glass construction
Cable management optimized for a simple and hassle-free build
Streamlined VR access with HDMI and USB 3.0 from the top IO
Easy-to-use headset and VR cable management puck
Full Kraken Series cooler support up to 280mm
Integrated PSU shroud with three SSD mounts
Fully filtered, easy-to-remove intake
