NZXT H510 Elite Review
Up Close: Interior
Up Close:  Interior
All nice and clean looking in here.  Although to be honest we were hoping for at least some of the cable management holes to be rubber grommeted, especially those at the top for the CPU and some fan cables, and those along the bottom of the motherboard area.
We do though appreciate that the vertical cable bar does a very good job of hiding the major cables, and looks like it will be pretty easy to work with.
In the bottom of the case there's a CPU shroud which is ventilated only in its rear part, which is fine for us as there's no need for anything more than this to be ventilated.  It's also possible to mount an SSD on here, but you will need to use one of the caddies from the rear, as an additional is not supplied.
 From the inside we can again see the 7 horizontal, and 2 vertical PCI covers.
Looking up into the roof we observe that the rear fan is a boring non LED unit which is a shame in a case that plays so heavily to its aesthetics.  We also see the area in which its possible to mount a 120mm or 140mm fan should you so desire.
The rear fan might not be LED, but there is an RGB LRD strip which covers most of the length of the roof of the case.  The way it's positioned, it should stay well out of sight, whilst at the same time giving good illumination to the interior.
«Prev 1 2 3 4 5 6 7 8 Next»
03-08-2019, 09:19:29
demonking
I know there is a lot of tempered glass on this case but it does seem expensive. I'd be concerned about the amount of air those front fans would have access to.
I fully agree though great looking case but missing quite a few features for the price. Nice reviewQuote
05-08-2019, 10:19:54
Digikid
I am sorry but NZXT needs to offer more for the money that they want for this case. No rubber dampeners, 120mm rear, no filter on top fan hole, ty CAM software required if you want to use the controller ( rip that junk out and get something else...ANYTHING else will be loads better ) improper front air holes...all of this just for a piece of glass on the front.
Sorry NZXT but this case just screams WE ARE GREEDY AND WILL GIVE YOU MINIMAL STUFF WHILE ASKING FOR MORE $$$!!!!
Even my S340 Elite is far superior to this thing. Quite disappointing indeed. Quote
06-08-2019, 14:41:22
Greenback
I'd say take the glass of and it's a £50 case really looks like a budget case with glass to make it look goodQuote
