NZXT H510 Elite Review
If you've been following the rollout of the 500 series from NZXT you might have been expecting the appearance of a "flagship" model.  If you were, then the H510 Elite might just be it.  If, however, this isn't your first rodeo, you might be suspicious that NZXT has simply bolted on a few extras and pumped up the price.  Well, that's where we come in.  So is this a true Luxury model, or just a bog-standard "L" model with a few tweaks and a bit of extra trim?  best we have a look at the tech specs to see what can be learned there.
Dimensions210x460x428 mm (W x H x D)
MaterialSteel Chassis, Tempered glass panels
Weight7.5kg
MotherboardM-ATX, ITX ATX,
5.25"0
3.5"2 + 1
2.5"2 + 1
Front I/O1xUSB Gen 3.1 Gen 2 type C, 1xUSB 3.1 Gen1 Type A, !x Headset Audio Jack (adapter supplied)
Expansion Slots7 horizontal + 2 vertical.
Air Cooling
Front: 2x140mm, 120mm (2x AER RGB 140mm included)
Roof: 1x120/140
Rear: 1x120 (1x120 non rgb included)
Water Cooling
Front: 240mm
Roof: N/A
Rear: 120mm
Max CPU Cooler Height165mm
Max GPU Length368.5mm
Max PSU LengthNot confirmed but up to at least 170mm
«Prev 1 2 3 4 5 6 7 8 Next»
03-08-2019, 13:19:29
demonking
I know there is a lot of tempered glass on this case but it does seem expensive. I'd be concerned about the amount of air those front fans would have access to.
I fully agree though great looking case but missing quite a few features for the price. Nice reviewQuote
05-08-2019, 14:19:54
Digikid
I am sorry but NZXT needs to offer more for the money that they want for this case. No rubber dampeners, 120mm rear, no filter on top fan hole, ty CAM software required if you want to use the controller ( rip that junk out and get something else...ANYTHING else will be loads better ) improper front air holes...all of this just for a piece of glass on the front.
Sorry NZXT but this case just screams WE ARE GREEDY AND WILL GIVE YOU MINIMAL STUFF WHILE ASKING FOR MORE $$$!!!!
Even my S340 Elite is far superior to this thing. Quite disappointing indeed. Quote
06-08-2019, 18:41:22
Greenback
I'd say take the glass of and it's a £50 case really looks like a budget case with glass to make it look goodQuote
