Kolink Phalanx Review
You might not have heard much about Kolink, but believe it not, they've been around since the mid 90s, designing, developing and manufacturing coolers and other PC related goodies with such esteemed partners such as Noctua.  What we have here then is the Kolink Phalanx, which at first view doesn't appear to be anything that special by today's standards.  It has a steel frame, with a full size tempered glass window, it has a brushed aluminium front with plenty of I/O options. It can take Motherboards up to E-ATX, has plenty of water cooling options and has 4x120mm Digitally addressable RGB fans included, with the option to install more all of which can be controlled by the integrated hub and bundled remote control.  All that for a hundred and...Hang on, this thing costs just £79!  Surely that can't be right.
Dimensions210 x 510 x 445 mm (W x H x D)
MaterialSteel Chassis, Aluminium front, Tempered glass panels
Weight 6.9kg
MotherboardM-ATX, ITX ATX, E-ATX
5.25" 0
3.5" 2 + 2 (shared with 2.5")
2.5" 4 (2 shared with 3.5")
Front I/O 2x USB2.0 1xUSB 3.0, Audio in/Out
Expansion Slots 7
Air Cooling
 Front: 3x120 (3x120 DRGB included)
 Roof: 2x120/140
 Rear: 1x120 (1x120 included)
Water Cooling
 Front: 120/240/360.
 Roof: 120/240.  140/280
 Rear: 120mm
Max CPU Cooler Height 160mm
Max GPU Length 370mm
Max PSU Length 170mm
«Prev 1 2 3 4 5 6 7 8 Next»
