Kaby Lake 7700K 5GHz AIO Cooler Mega Test
SilverStone Tundra TD02 E
Price @ OCUK:  £89.99
Technical Specification
Radiator Dimensions278x124x27mm
CPU Intel 775 115x, 1366, 2011, 2011-3.  AMD FM1/2, AM2/3
FPI 12
Water Channels  12
Fan Speed 2x120mm @ 2500rpm
Airflow 92.5CFM
Air Pressure 3.5mmH2O
Fan Noise level 35dB(A)
Up Close
As you might have guessed from the identically themed packaging, the TD02 E comes from the same line as the previously reviewed TD03 E, although we're not quite sure why the larger of the two coolers should have the smaller digit associated with it (I guess we're missing something obvious, so do be sure to point it out in the comments)
The TD02 E comes with a pair of monochromatic SilverStone fans which are identical in every respect to those that come packaged with the TD03 E.  The fans will rev up to 2500rpm and can move 92.5CFM with a static pressure of 3.5mm H2O and a manufacturers stated noise level of 35dB(A)
The TD02 E also has perspex side panels, but instead of using a single piece, which we think would have looked nicer, they have instead just used two of the 120mm panels used on the TD03 E
The screw-less contact plate really is a thing of beauty, as is to be honest the whole single piece Aluminium block that forms the housing.  To aid in flexibility, the tubing joins the block with 90 degrees rotary joints.
We thought we'd give you a close up of the Brazing fins that SilverStone have opted for instead of the more commonly seen type.  The fins are quite a bit thicker than the usual type, and are very robust indeed.  It's also worth noting that the screw holes have small rubber pads around them to aid in noise and vibration dampening.
The matte black rubber hosing is quite flexible and resists kinking well.  Although not having posh braiding, we do quite look the Black rubber look (ahem).
The TD02 E installs with ease thanks to the intuitive fitting method and clear instructions.  As there's no speed altering software or hardware, we'll just be testing this at the full 12v, along with the Vardars of course.
Ok, so it doesn't have RGB LEDs, but the SilverStone snowflake does light up a nice cool ice blue when the pump is operational.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Next»
03-01-2017, 13:38:46
euphoriatle
No Kraken X62 ?Quote
03-01-2017, 13:40:15
tinytomlogan
Originally Posted by euphoriatle View Post
No Kraken X62 ?
Not in this round up no. NZXT failed a bit.Quote
03-01-2017, 13:47:59
euphoriatle
No probs just curious how the 'pretty' pump compared on the kaby 5ghz lolQuote
03-01-2017, 13:53:43
IceBErgs
No enermax?Quote
03-01-2017, 18:48:08
dwatterworth
Amazing amount of in depth analysis and explanation fellows, as always, thank you for not only presenting detailed and thorough information but explaining the points you make and why certain aspects/elements are more effective.
Great to see Cryorig putting up great figures. Seems like all of their offerings are at least solid, if not phenomenal, especially for the value.Quote
