Fractal Design Meshify S2 Review
It would be something of an understatement to say that Fractal have an extensive range of cases.  Take a look at their website, (linked above), and you'll see that they cater for pretty much every element of your sub costal, cardiac pump's desire.  So where then does the Meshify S2 fit into this extensive range?  Well, to be honest, right now we're not entirely sure, but if you stay with us hopefully we'll define the niche that the S2 fits into (Define...get it???... Nevermind)
As we are currently pre-NDA, at the time of writing, there are no formal measurements or specifications for the S2.  We will though try to do our best to fill in a few blanks from pre-release information, and as details emerge we will further populate the table below.  For now though, here's what we have.
Dimensions 538x223x456  (LxWxH)
MaterialSteel Chassis, Plastic trim, Tempered glass panels
Weight 9.52kg
MotherboardM-ATX, ITX ATX, EATX (up to 285mm wide)
5.25" 0
3.5" 3 (shared with 2.5")
2.5" 7 (3 shared with 5.25")
Front I/O 1xUSB3.1 gen 2 Type C, 2xUSB3.0, Audio in/Out
Expansion Slots 7 + 2 vertical
Air Cooling
 Front: 3x120/140 (2x140 included)
 Roof: 3x120/140
 Rear: 1x120/140 (1x140 included)
 Base: 2x120/140
Water Cooling
 Front: 120/240/360.  140/280 (max 147 mm width)
 Roof: 120/240/360.  140/280/420 (max 35mm   component MB Height
 Rear: 120mm
 Base 120/20. 140/280
Max CPU Cooler Height 185mm
Max GPU Length 440mm with front mounted 25mm thick fans
Max PSU Length300mm
«Prev 1 2 3 4 5 6 7 8 Next»
23-01-2019, 15:23:48
WillSK
Ahhh man I just bought an S2...
To be fair no complaints, it's probably the best made case I've ever owned and I've had a fewQuote
23-01-2019, 15:33:06
Himei
Aww man, I just brought the Meshify. I didn't even get all my parts together yet for it.Quote
23-01-2019, 16:03:03
looz
That graphics card looks slightly out of place. Quote
23-01-2019, 16:52:53
Wraith
Want! So much want! I miss my Define S.Quote
03-02-2019, 10:31:45
Ishimuro
So.... As a guy who likes white Cases and has seen both: This one or the H500P white @Tom? Struggeling so hard right now xDQuote
