EVGA DG-77 Review
EVGA DG-77 Review
The DG-77 we have for review today is part of the larger DG-7 range, which in simple terms cover options with ever increasing amounts of tempered glass and a choice of black or white.  If you're not a fan of tempered glass cases, then to be honest, it's best you look away now.  If however you love the tempered glass look, then this is a case you need to be looking at.  To get a better idea of what the smoked glass interior is concealing, best we have a look at the technical specification.
Dimensions477x211x470mm (HxWxD)
MaterialSteel and Tempered Glass
Motherboard supportATX, M-ATX, M-ITX
2.5"4 (2 shared with 3.5")
3.5"2
Air Cooling
Front:  3x120mm, 2x140mm (2x120mm included)
Roof:   3x120mm, 2x140mm (1x120mm included)
Rear:   1x120mm (Included)
Water Cooling
Front:  Up to 360, 280mm
Roof:
Rear:   1x120mm
Rear expansion 7
Front I/OPower, Reset, HD Audio, 2xUSB3.0, K Boost
Weight8.79kg
«Prev 1 2 3 4 5 6 Next»
