CoolerMaster MasterAir Pro 4 Review
Packaging and Contents
The MasterAir Pro 4 comes in a quite small box sporting the now familiar CoolerMaster colours.  With such a small box, we're wondering just how well the product inside is protected.
It might be a little box, but that hasn't stopped CoolerMaster from slipping in all the usual information we've come to expect of a manufacturer.  You know, for when you buy these off the shelf in a shop and need to look at the spec, as opposed to online where most purchases are made.
What!  No egg box card packaging?  Are CoolerMaster trying to kill the planet?  To be honest though, we can't hate them for using a little plastic to protect it, and this sort of design works pretty well
Ah, the little pack of goodies, beautifully presented as always in their hinged vacuum sealed tray.  The rest of the accessories box contains nearly everything you need to fit pretty much all AMD and Intel CPPUs, although you will need to source a separate braket for Ryzen at present.
Did any of you spot that there wasn't a back plate in the picture above?  Be honest, you didn't.  Well rest assured there is one, but to save space CoolerMaster have attached it to the rear of the plastic packaging.  Clever CoolerMaster!
The instructions aren't immediately clear until you realise that they are actually describing two different methods of attaching the cooler to the CPU.  Actually, if we're honest, they're not that much clearer even after you've realised this.
«Prev 1 2 3 4 5 6 7 8 Next»
10-04-2017, 06:50:34
Doomslayer
IMO never understood why you would want to put one of these cheaper CPU coolers on a socket 2011/V3 if you spending that much money on the X99 motherboard you should be going with an AIO or a higher end CPU cooler.Quote
10-04-2017, 14:45:00
warpuck
When a AIO clogs up you toss it. When a Noctua C/D 14 clogs up, remove fan and suck out the clog with brush and vacuum cleaner. The fan should last 5 years or more. So the only thing that is left with a AIO is the fans. DIY water has got to be cleaned and drained if you use flexible tubing annually. Rigid maybe once every 3-5 years drained and cleaned. You still have to clean the dust out of the radiators 1 or 2 twice a year. They can both be moved to another socket style. I have had three different water cooler set ups and will not be using water again. A Noctua C or D 14 is almost as good as 240mm AIO and better than most if not all 120mm AIOs. If your ambient is 40C water is better, But 30C or less no real advantage. Truth I don't get any more DAILY Ghz out of a FX-8350 with water than I do with a C14Quote
10-04-2017, 15:17:47
NeverBackDown
Ever use a AIO?
I've used one virtually 24/7 for nearly what 2 years now? Never had a hiccup. This is an older 2nd gen AIO. Still going strong. The newer ones are even more robust. Really they will last as long as fans will.Quote
14-04-2017, 11:37:37
warpuck
Used a AIO 24/7 folding with a OCed FX-8350 (4.7Ghz). (200 watts +) 24/7 operation broke down the coolant corrosion inhibitors and it clogged up after about 1 year of that kind of abuse. A premium Noctua does almost as well as a AIO and it can be cleaned with small paint brush and a vacuum cleaner. A AIO is sent back if it is under warranty. Performing surgery on it is tedious, if it is out of warranty, plus it may not work again anyway. Considering that a Coolermaster 120mm x 40mm cost almost the same as Noctua 14 at the time? Water does cool better but it does have one more working part to fail and pumps will fail. I have 2 dead pumps now. Vapor condensation cycle has no moving parts, fans are plentiful and cheap enough to keep a spare around while you wait 50,000 hours for it to fail. I still have the Coolermaster fan that came with the AIO in use as a case fan. The 8350 is still happy folding @4.6 Ghz cooled by a Noctua NH-C14S with its companion GTX 690. Both cooling items have been discontinued. Only one still works. I have come to the conclusion that water is great if your system is only used for a few hours a day to squeeze the max out of your system.Quote
