CoolerMaster MasterAir MA410M Review
Published: 24th May 2018 | Source: CoolerMaster | Price: |
Full RGB LED enabled Heat sinks are very "de rigueur" at the moment, (and yes we know that means the same thing), in fact so much so that's it's getting hard to find a new release that hasn't been fully LED loaded. Where we appreciate the ability to integrate our case lighting with the colour scheme of our build, it's also important to us that the cooler does it's primary job, which is that of keeping the CPU cool. So with this in mind, let's take a look at those all important Technical Specifications to see if we can tell how the MA410M is going to perform.
Dimensions | 111.8x130.9x165.1mm |
Material | Aluminium funs |
Intel | LGA 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 / 1366 socket |
AMD | AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket |
Heatpipes | 4 |
Heat pipe Dimensions | 6mm |
Fans | 2x120mm 650-1800 RPM |
Air Flow | 53.38 CFM |
Air Pressure | 1.65mmH20 |
Noise | 31dB(A) |
