ASUS ROG Z11 ITX Gaming Case Review
GPU Support - Can your GPU be too thick?
ASUS ROG Z11 Gaming Case Review
The ROG Z11 is one major limitation, and that limitation is GPU support. To be more specific, we do not recommend using graphics cards which are close to three slots thick within this enclosure.
As an example, we do not recommend using ASUS' RTX 3080 Strix within this chassis, as its 2.9-slot design is difficult to install within the enclosure and is too tick to achieve adequate airflow. Nvidia's decision to increase the TDPs of their high-end RTX 30 series designs has forced many GPU makers to create thicker graphics cards, making this limitation very noticeable within the ROG Z11.
While ASUS' product page lists 3-slot GPU support, we do not recommend this kind of GPU configuration. Your graphics card will sit too close to the window of the Z11 and be starved of airflow. 3-slot GPUs can fit, but that doesn't guarantee a great user experience.
High-end GPU designs often run hotter in ITX enclosures. The compact nature of ITX products often comes at a thermal cost. With dual-slot cards like Nvidia's RTX 3080 Founders Edition, we noted a four-degree increase in GPU load temperatures over our ATX-sized GPU test system. We also noted that ASUS' 2.7-slot ROG RTX 2080 Ti Strix saw 5-6 degree increase in load temperatures when using the Z11.
With this date in mind, we do not recommend using graphics cards that are more than 2.7 slots thick with ASUS' ROG Z11 chassis. Dual-slot graphics cards are an ideal scenario for this chassis when it comes to airflow, with 2-2.7 slot GPUs being workable, but not ideal.
ASUS designed their Z11 before Nvidia increased their high-end TDPs and forced GPU makers to create thicker high-end graphics cards. Designing the ROG Z11 with 5-10mm of extra depth would have worked wonders when it came to 3-slot graphics card use. It's a shame that we cannot recommend using the ROG Z11 with the company's latest ROG Strix series graphics cards.
3-slot GPUs can fit, but at what cost?
ASUS' website claims that their ROG Z11 supports 3-slot graphics cards, and while these graphics cards can fit inside, they do not have enough airflow to deliver what we would call sufficient cooling. Perhaps ASUS needs to clarify its ROG Z11 product page to deliver clearer information regarding the ROG Z11's GPU support.
«Prev 1 2 3 4 Next»
22-10-2020, 08:18:20
Deadtroopers
That better have been a decent single malt, matey!
Okey smokey: Impressive build quality but at that price I would want NO plastic AT ALL. It is good that you can re-orientate the ROG eye seen thru the side panel; pity about the ROG logo by the graphics card when it is stood up!
Speaking of which: I want to see ALL my graphics card; that obscuring caused by the illuminated logo had my back up straight away. I'd go back to the drawing board and put it across the top as seen when vertically oriented; the external I/O I'd put along the bottom in two rows and with two intake vents either side above for balance (The card would appreciate more intake too!).
Personally I'd use the case horizontally, a hangover from the FT02.
This is so close it makes me grind my teeth: the lopsided, card obscuring, card starving, aesthetic I wouldn't pay £24 for; never mind £240. Sort the aesthetic, I'd probably buy two. ASUS, !!!Quote
22-10-2020, 09:37:16
tinytomlogan
Balvenie double cask Quote
