Antec Performance P120 Crystal Review
Antec performance P120 Crystal Review
Antec appears to have something of a Jekyll and Hyde design team.  By that I mean they're either producing quite tame, vanilla and gentlemanly cases, such as various generations of the classic Sonata and all of its spin offs, or they're letting the monster off the leash with cases such as the Skeleton, and the current Torque and Striker cases.  I grant you that there are a few cases in the middle ground, but these are manly 'normal' chassis' with added plastic trim and a some RGB LED fans, not that there's anything wrong with this, and it's a practice undertaken by practically every other case manufacturer in the market.  We also appreciate that cases making extensive use of tempered glass have been around for quite a while now which begs the question as to how the P120 Crystal varies.  What does it bring to the party that the other glass paneled cases don't?  At first view the Technical Specifications don't seem that out of the ordinary, but look at them closely and you'll see something of an anomaly.  Found it yet???
Dimensions 476x234x485mm  (LxWxH)
Material Steel Chassis, Tempered glass panels
Weight
 10.4kg
Motherboard M-ATX, ITX ATX, E-ATX
5.25" 0
3.5"/2.5" 2x3.5", with additional 2.5" underslung
Dedicated 2.5" 2
Front I/O 2x white LED USB3.0, HD Audio in/Out
Expansion Slots 7 + 3 vertical
Air Cooling
 Front: None
 Roof:  None
 Side:  Up to 3x120mm or 2x140mm 1xHDD bracket needs to be removed for 3x120mm
 Rear: 1x120/140
 Base: 3x120/140
Water Cooling
 Front:  None
 Roof:   None
 Rear: 1x120mm <160mm
 Base: Up to 360mm (max 28mm thick)
 Side:  Up to 360mm (all HD brackets need to be removed)
Max CPU Cooler Height 185mm
Max GPU Length 450mm
Max PSU Length 394mm
«Prev 1 2 3 4 5 6 Next»
17-12-2019, 16:44:39
Avet
I like the design. PSU top leaves clear airflow for GPU and components. The idea is good but there are too many price cutting compromises.
Is is that hard to give 10 mm extra space for cables?
That "dust filter" on side panel is just waste of money. Yes it does reduce the amount of dust entering the system by stopping the air moving. Glass panel does the same thing.
Too much metal is blocking fans. Bottom should be like side radiator mount. If you are not using fans there 3 peaces of metal with thumbscrews to cover them aren't that much more expensive.Quote
17-12-2019, 20:19:53
RobM
So the new trend will be top PSU, back to the 90s lolQuote
