Anidees AI5S Case Review
Up Close: Interior
Anidees AI5S Review
Up Close:  Interior
We're still looking at this case and not quite believing that it can take a full size ATX motherboard.  Seriously?  Where?  OK so appreciating that it can, what else do we have?  Well, although there's a distinct absence of rubber grommeted management holes, there is a rather nice angled baffle over to the right, which should do the same job just as well, but in a slightly different way.
Anidees AI5S Review
The front of the case has room for 2x140mm fans, or 3x120mm fans.  Out of the box you get a pair of 120mm units, which is more than generous for a case at this price point.  The observant among you though will have spotted the elongated slots for fan and radiator mounting...What joys await!!!
Anidees AI5S Review
The base of the case has a full length false floor, with just the slightest cut out for a 25mm thick fan.  Having slagged off cases that stop short of full width floors, we have to say we're in favour of the full length option, and are willing to forgive the slight cut out for an additional fan.  For those of you who like to "flash your drives", the false floor has a pair of show off mounts for both 2.5" and 3.5" drives.
Anidees AI5S Review
the rear is a pretty standard affair, with eight vented PCI slot covers and a crystal 120mm fan above, with slots for a 140mm unit.
Anidees AI5S Review
A glance into the roof gives us a bit more of an inkling as to the water cooling credentials of this case.  We might be mistaken, but those look an hell of a lot like slotted stand off mounts for 240 and 280mm rads.
Anidees AI5S Review
«Prev 1 2 3 4 5 6 Next»
03-04-2017, 14:22:00
Avet
Why do I see Fractal Design Define C?Quote
03-04-2017, 14:45:40
AlienALX
Because you pretty much do
haha a mate of mine modded his Fractal by cutting it down quite severely. Then we get the Define C and now this funny how things go sometimes !Quote
04-04-2017, 01:34:49
Peace
The last picture on page 4 makes me cringe... A loosened screw/bolt?Quote
04-04-2017, 04:52:02
sheroo
Wish the Fractal C had come with a stock fan controller like this one does...Quote
04-04-2017, 10:38:26
Avet
I don't see the point with fan controlers now. Motherboards have plenty of connectors. You can go 3-way split on everyone of them.Quote
