Anidees AI5S Case Review
Up Close: Exterior
Anidees AI5S Review
Up Close:  Exterior
With measurements of just 430x220x470mm (HxWxD), you too would be forgiven for thinking that the AI5S from Anidees is actually an M-ATX motherboard sized case, after all, we've seen M-ATX cases that are a little bigger than this chap so it'd be a fair enough assumption.  The AI5S is though in fact a fully fledged ATX case and, as you'll see it makes use of every last millimeter of internal space
Anidees AI5S Review
With the left side sporting a smallish window, the right side is left clean and crisp.  The front of the case is plastic, but finished to a high degree with mock Aluminium line brushing.
Anidees AI5S Review
The top of the case has a removable magnetic mesh filter. hiding underneath which are what look to be some fairly exciting radiator mounts.  What's also promising is that they appear to be stood off a large amount from the Motherboard.
Anidees AI5S Review
The front I/O consists of a pair of both USB 2.0 and 3.0s, as well as a power and reset button.  Over to the left there's also a three speed fan controller, which is a very nice touch.
Anidees AI5S Review
The rear of the case is a standard ATX affair, with eight removable vented PCI covers.  These are the proper sort that can be re inserted at a later date, as opposed tot he pop out sort that can't be re-inserted.
Anidees AI5S Review
Underneath there's a good sized PSU vent with slide out dust filter, with the case standing on four fairly hard rubber tipped plastic feet.
Anidees AI5S Review
«Prev 1 2 3 4 5 6 Next»
03-04-2017, 14:22:00
Avet
Why do I see Fractal Design Define C?Quote
03-04-2017, 14:45:40
AlienALX
Because you pretty much do
haha a mate of mine modded his Fractal by cutting it down quite severely. Then we get the Define C and now this funny how things go sometimes !Quote
04-04-2017, 01:34:49
Peace
The last picture on page 4 makes me cringe... A loosened screw/bolt?Quote
04-04-2017, 04:52:02
sheroo
Wish the Fractal C had come with a stock fan controller like this one does...Quote
04-04-2017, 10:38:26
Avet
I don't see the point with fan controlers now. Motherboards have plenty of connectors. You can go 3-way split on everyone of them.Quote
