AMD Ryzen 5 & 7 CPU Cooler Round Up
Corsair H100i V2
AMD Ryzen 5 & 7 CPU Cooler Mega Test
Corsair H100i V2
The Corsair H100i is easily one of the most popular AIO liquid coolers on the market, bringing system builders an easy to use 240mm liquid cooling unit that is designed for CPU overclocking and quiet operation.
Specification:
- Radiator dimensions: 276mm x 125mm x 30mm
- Fan dimensions: 120mm x 120mm x 25mm
- Fan speed: 2435 +/- 10% RPM
- Fan airflow: 70.69 CFM
- Fan static pressure: 4.65 mmH2O
- Fan noise level: 37.7 dB(A)
Box Contents:
- Corsair Hydro Series H100i v2
- Mounting kit for all modern CPU sockets
- Two SP120L High Torque 120mm fans
- USB cable for Corsair Link. Integration
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
AMD Ryzen CPU Cooler Mega Test
AM4 Compatability
Corsair's H100i V2 is compatible with AMD's AM4 socket, but the cooler will require an AM4 mounting bracket. This is available from Corsair for free for a limited time, though the company does allow users to purchase this bracket for £4.
You can fin out more about the AM4 compatibility of Corsair's CPU coolers here.
 Current Price - £106.99
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Next»
25-04-2017, 14:36:07
NeverBackDown
Such a shame for a low temp limit. This kinda hurts the argument that AMD platform is cheaper right now since you need to invest into a strong cooler to maintain the OCs most people aim forQuote
25-04-2017, 15:28:27
WYP
But at the same time how many people overclock on X99 without a large cooler.
I do agree with you, raising the thermal limit with Ryzen 2 would be fantastic, as it could allow even basic air cooling to handle higher overclocks/voltages. If it were 80 Degrees I think even the Cryorig H7 would have passed OC testing on the 8-core.Quote
25-04-2017, 15:36:06
Greenback
Thanks for all the work Tom and your helping hands, Was interesting how little difference between the 12v and 7v think I'd go for a little warmer quieter system.
Tbh I'd think if your looking at overclocking either Intel or AMD you'd most lightly look at an AIOQuote
25-04-2017, 16:02:06
Streetguru
I use the $25 Hyper T4 to cooler my R7 1700 at 3800-3900mhz @ 1.4V and it seems to work just fine, granted I've upgraded the fan to a 140mm High Pressure Venturi fan, but it's probably not too much better than the stock fan. fan ran at 100% RPM, controled by a Sentry Mix 2 fan controller, super handy to have btw
Rarely breaks 60C running in a hot shed.
I would highly recommend a deepcool gammax 400 instead though, as it has cut outs to fit RAM, i wouldn't be able to put RAM into the 1st slot if I needed to upgrade to 32GBs, since I can't turn the heatsink on AM4 anyways.Quote
25-04-2017, 18:53:31
NeverBackDown
most enthusiasts would, but not everyone will. Especially those people buying the 1600/x CPUs. Either way, spending all that money on a cooler hurts the "cheaper" argument people, including me, would use. It'll still end up cheaper of course than an intel system, but still more money is still more money.Quote
