AMD Ryzen 5 & 7 CPU Cooler Round Up
Cryorig H7
AMD Ryzen 5 & 7 CPU Cooler Mega Test
Cryorig H7
The Cryorig H7 is a single tower CPU cooler which uses a 120mm fan and comes at an ultra-affordable price of £36.95, this cooler is a staple for budget builders, offering a three-year warranty and compatibility with all major CPU sockets.
This cooler does not come with an AM4 mounting kit out of the box, but Cryorig does provide this kit for free if users can provide proof of purchase or pictures of their cooler.
Heatsink Specification
- Dimension ( with fan ): L98 mm x W123 mm x H145 mm
- Weight ( with fan ): 711 g
- Weight ( without fan ): 577 g
- Heat pipes: 6mm heatpipe x 3 units
- Fin: T = 0.4 mm ; Gap = 2.2 mm
- Front Fin Pcs: 40 pcs
- Copper Base: C1100 Pure copper nickel plated
- RAM Tolerance Height: Limitless
- TDP: 140 W
Fan Specification:
- Dimension: L120 mm x W120 mm x H25.4 mm
- Weight: 134 g
- Rated Speed: 330 ~ 1600 RPM ±10 %
- Noise Level: 10 ~ 25 dBA
- Air Flow: 49 CFM
- Air Pressure: 1.65 mmH2O
- Ampere: 0.16 A
Current Price - £36.95
AM4 Compatability
A wide range of Cryorig coolers are compatible with AMD's AM4 socket thanks to the companies AM4 upgrade bracket, this bracket is available free of charge to those that can provide proof or purchase for their Cryorig cooler and an AM4 CPU/motherboard.
Cryorig users can apply for a free upgrade bracket here
   CRYORIG will provide all existing users and new owners of AMD supported products the new AM4 kit totally free of charge. Existing eligible products include: R1 Universal/Ultimate, C1, H5 Universal/Ultimate, H7, H7 Quad Lumi, M9a, C7, A40, A40 Ultimate and A80.
Users only need to the following information: proof of purchase of the CRYORIG product (or product registration number), and a proof of purchase of a AMD Ryzen or AM4 CPU. Just fill out and supply all necessary info at www.cryorig.com/getam4.php, the kit will be sent directly to the provided address. Local distributors and select channels will also have these kits available.
AMD Ryzen CPU Cooler Mega Test
Up Close
This cooler offers a compact design that has no problems with large memory kits on AM4, leaving plenty of space to replace memory kits or otherwise work inside out Corsair Air 240 chassis.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Next»
25-04-2017, 14:36:07
NeverBackDown
Such a shame for a low temp limit. This kinda hurts the argument that AMD platform is cheaper right now since you need to invest into a strong cooler to maintain the OCs most people aim forQuote
25-04-2017, 15:28:27
WYP
But at the same time how many people overclock on X99 without a large cooler.
I do agree with you, raising the thermal limit with Ryzen 2 would be fantastic, as it could allow even basic air cooling to handle higher overclocks/voltages. If it were 80 Degrees I think even the Cryorig H7 would have passed OC testing on the 8-core.Quote
25-04-2017, 15:36:06
Greenback
Thanks for all the work Tom and your helping hands, Was interesting how little difference between the 12v and 7v think I'd go for a little warmer quieter system.
Tbh I'd think if your looking at overclocking either Intel or AMD you'd most lightly look at an AIOQuote
25-04-2017, 16:02:06
Streetguru
I use the $25 Hyper T4 to cooler my R7 1700 at 3800-3900mhz @ 1.4V and it seems to work just fine, granted I've upgraded the fan to a 140mm High Pressure Venturi fan, but it's probably not too much better than the stock fan. fan ran at 100% RPM, controled by a Sentry Mix 2 fan controller, super handy to have btw
Rarely breaks 60C running in a hot shed.
I would highly recommend a deepcool gammax 400 instead though, as it has cut outs to fit RAM, i wouldn't be able to put RAM into the 1st slot if I needed to upgrade to 32GBs, since I can't turn the heatsink on AM4 anyways.Quote
25-04-2017, 18:53:31
NeverBackDown
most enthusiasts would, but not everyone will. Especially those people buying the 1600/x CPUs. Either way, spending all that money on a cooler hurts the "cheaper" argument people, including me, would use. It'll still end up cheaper of course than an intel system, but still more money is still more money.Quote
