AMD Ryzen 5 & 7 CPU Cooler Round Up
NZXT X62
AMD Ryzen 5 & 7 CPU Cooler Mega Test
NZXT X62
The NZXT X62 is largest AIO liquid cooler that NZXt currently produces, coming with a 280mm radiator and two static pressure optimised 140mm fans.
With RGB illumination, a reflective pump top with a mirror shine and a large 280mm radiator, this cooler is designed to be a premium product, with this cooler being the most expensive cooler that we are testing today.
Radiator:
- Dimensions (LxWxH)(mm): 315 x 143 x 30
- Material: Aluminum
- Weight: 1.29g
Pump & Water Block
- Dimensions (LxWxH)(mm): 80 x 80 x 52.9
- Material: Copper, Plastic
- Variable Pump Speed: 1,000 - 2,800 ± 300 RPM
- Pump Control: Silent/Performance/Custom/Manual
Fan
- Model: Aer P140 PWM Fan
- Quantity: 2 x 140mm
- Fan Modes: Silent/Performance/Custom/Manual
- Speed: 500-1,800 ± 300 RPM
- Noise: 21-38dBA
- Warranty: 6 Years
Current Price - £149.99
AMD Ryzen CPU Cooler Mega Test
AM4 Support
NZXT's X52 does not support AMD's AM4 socket out of the box, with NZXT providing AM4 mounting brackets to users who own NZXT Kraken series AIO.
(1) Visit https://www.nzxt.com/customer-support and submit a ticket.
(2) Choose “AM4 Bracket Support” as your department.
(3) Attach your Kraken series AIO liquid cooler proof of purchase.
(4) Attach your motherboard with AM4 socket proof of purchase.
Upon validation, the bracket will be shipped to you free of charge.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Next»
25-04-2017, 14:36:07
NeverBackDown
Such a shame for a low temp limit. This kinda hurts the argument that AMD platform is cheaper right now since you need to invest into a strong cooler to maintain the OCs most people aim forQuote
25-04-2017, 15:28:27
WYP
But at the same time how many people overclock on X99 without a large cooler.
I do agree with you, raising the thermal limit with Ryzen 2 would be fantastic, as it could allow even basic air cooling to handle higher overclocks/voltages. If it were 80 Degrees I think even the Cryorig H7 would have passed OC testing on the 8-core.Quote
25-04-2017, 15:36:06
Greenback
Thanks for all the work Tom and your helping hands, Was interesting how little difference between the 12v and 7v think I'd go for a little warmer quieter system.
Tbh I'd think if your looking at overclocking either Intel or AMD you'd most lightly look at an AIOQuote
25-04-2017, 16:02:06
Streetguru
I use the $25 Hyper T4 to cooler my R7 1700 at 3800-3900mhz @ 1.4V and it seems to work just fine, granted I've upgraded the fan to a 140mm High Pressure Venturi fan, but it's probably not too much better than the stock fan. fan ran at 100% RPM, controled by a Sentry Mix 2 fan controller, super handy to have btw
Rarely breaks 60C running in a hot shed.
I would highly recommend a deepcool gammax 400 instead though, as it has cut outs to fit RAM, i wouldn't be able to put RAM into the 1st slot if I needed to upgrade to 32GBs, since I can't turn the heatsink on AM4 anyways.Quote
25-04-2017, 18:53:31
NeverBackDown
most enthusiasts would, but not everyone will. Especially those people buying the 1600/x CPUs. Either way, spending all that money on a cooler hurts the "cheaper" argument people, including me, would use. It'll still end up cheaper of course than an intel system, but still more money is still more money.Quote
