AMD Ryzen 5 & 7 CPU Cooler Round Up
Cooler Master Master Liquid 240
AMD Ryzen 5 & 7 CPU Cooler Mega Test
The Cooler Master MasterLiquid 240 is the first CPU cooler that we have tested to support AMD's AM4 platform out of the box, which means that users do not need to spend any time or money to get an AM4 mounting kit upgrade for Ryzen.
This cooler is designed to be a more affordable version of the companies Master Liquid Pro 240 liquid cooler, coming with a price tag of £79.99, making this the cheapest AIO liquid cooler that we are testing today.
CPU Socket
- Intel: LGA 2011-3/2011/1366/1156/1155/1151/1150/775,
- AMD: FM2+/FM2/FM1/AM3+/AM3/AM2+/AM2/AM4
- Waterblock Dimensions (LxWxH): 85.6(L) x 70(W) x 49(H) mm
Radiator Material
- Aluminium (Radiator)
- Copper (Baseplate)
- FEP (Tubing)
Fan
- Fan Dimensions (LxWxH): 120(L) x 120(W) x 25(H) mm
- Fan Speed: 650-2,000 RPM ± 10%
- Fan Airflow: 66.7 CFM ± 10%
- Fan Air Pressure: 2.34 mmH2O ± 10%
- Fan Life Expectancy: 160,000 hrs
- Fan Noise Level (dBA): 6-30 dBA
- Fan Bearing Type: POM Bearing
- Fan Connector: 4-Pin (PWM)
- Fan Rated Voltage: 12 VDC
- Fan Rated Current: 0.16 A
- Fan Power Consumption: 1.92 W
Pump
- Pump Life Expectancy: 70,000 hrs
- Pump Noise Level:
- Pump Rated Voltage: 12 V
- Pump Rated Current: 0.5 A
- Pump Power Consumption: 6 W
- Warranty: 2 years
Current Price - £79.99
AMD Ryzen CPU Cooler Mega Test
AM4 Compatability
This cooler comes with full AM4 support out of the box, allowing this cooler to be used with Ryzen without the need to order an aftermarket AM4 mounting kit.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Next»
25-04-2017, 14:36:07
NeverBackDown
Such a shame for a low temp limit. This kinda hurts the argument that AMD platform is cheaper right now since you need to invest into a strong cooler to maintain the OCs most people aim forQuote
25-04-2017, 15:28:27
WYP
But at the same time how many people overclock on X99 without a large cooler.
I do agree with you, raising the thermal limit with Ryzen 2 would be fantastic, as it could allow even basic air cooling to handle higher overclocks/voltages. If it were 80 Degrees I think even the Cryorig H7 would have passed OC testing on the 8-core.Quote
25-04-2017, 15:36:06
Greenback
Thanks for all the work Tom and your helping hands, Was interesting how little difference between the 12v and 7v think I'd go for a little warmer quieter system.
Tbh I'd think if your looking at overclocking either Intel or AMD you'd most lightly look at an AIOQuote
25-04-2017, 16:02:06
Streetguru
I use the $25 Hyper T4 to cooler my R7 1700 at 3800-3900mhz @ 1.4V and it seems to work just fine, granted I've upgraded the fan to a 140mm High Pressure Venturi fan, but it's probably not too much better than the stock fan. fan ran at 100% RPM, controled by a Sentry Mix 2 fan controller, super handy to have btw
Rarely breaks 60C running in a hot shed.
I would highly recommend a deepcool gammax 400 instead though, as it has cut outs to fit RAM, i wouldn't be able to put RAM into the 1st slot if I needed to upgrade to 32GBs, since I can't turn the heatsink on AM4 anyways.Quote
25-04-2017, 18:53:31
NeverBackDown
most enthusiasts would, but not everyone will. Especially those people buying the 1600/x CPUs. Either way, spending all that money on a cooler hurts the "cheaper" argument people, including me, would use. It'll still end up cheaper of course than an intel system, but still more money is still more money.Quote
