Corsair HS70 Wireless Gaming Headset
Software
Software
The HS70 is supported by the CUE software, allowing you to tweak the EQ to your own personal taste if you have a particular set of desires. Thankfully as this software isn't available on the PS4 the HS70 default profile is outstanding. Usually even the best headsets require a little bit of fiddling either because they have a profile which is too flat and lifeless or - because the marketing department think that ridiculous bass is a positive quality - to smooth out an EQ too skewed in one direction. The HS70 has no such issues.
«Prev 1 2 3 4 Next»
31-05-2018, 11:25:38
Dicehunter
The detachable mic is a huge selling point for me as I use the Void Pro's every day and the mic does get in the way, I'll have to pic this up at some point.Quote
31-05-2018, 11:45:20
TheDuke
Thanks for the review Tom, I gave up on gaming headphones a long time ago I have bought to many high-end so called gaming headphones and was always disappointed with the sound and comfort, in the end I decided to buy a modmic 5, this would give me the best of both worlds the use of my beyerdynamic dt 990 edition 250 ohm headphones and the use of a detachable MIC, saying that I was still not impressed with the comfort levels and had to change the default ear-pads as they where to hard even after wearing them for a few weeks to more comfortable one after much research I decided on the Dekoni Audio Elite Sheepskin Leather Ear Pads, for comfort and longevity. I also changed the memory foam out of the headband and replaced it with super soft latex foam.I am very happy with the results Quote
04-06-2018, 10:20:55
fadingfool
And I'd just paid out for a set of Wireless Void Pro's..... Oh well at least the lights (that I can't see when wearing them) match the rest of my set up.Quote
