Thermaltake's launches All-new Toughpower GF3, iRGB, and SFX Series PSUs for high wattage PCs
Thermaltake's new Toughpower GF3 and SFX series units feature PCIe 5.0 12+4 connectors
Published: 13th July 2022 | Source: Thermaltake - Press Release |
Press Release - Thermaltake Announces All-new Toughpower GF3, iRGB, and SFX Series PSUs
Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals, and enthusiast memory solutions, unveils brand-new power supplies including GF3, iRGB, and SFX series. The GF3 series and the SFX series, in particular, are PCIe Gen 5 ready, meaning these power supplies come with a 12+4 pin interface and can natively support the upcoming RTX 4000 series graphics cards, and come in different wattages of your choice.
Let's start with the Toughpower GF3 series. The entire lineup is fully modular and designed with a native 12+4 pin PCIe Gen 5 connector and is compatible with Intel's ATX 3.0 specification, uncovering the new experience the next-gen PCIe has to offer. The GF3 1650 W, particularly, natively supports two PCIe 14+2 pins, making it possible to deliver power to two high-end graphics cards simultaneously. The fully modular Toughpower GF3 series comes in 1650 W, 1350 W, 1200 W, 1000 W, 850 W, and 750 W and is built to deliver 80 PLUS Gold efficiency. Aimed at providing the best performance, the Toughpower GF3 series comes with 100% high-quality Japanese capacitors and delivers reliable power, ensuring smooth and stable operation as well as steady and clean power through voltage stability.
For the Toughpower iRGB PLUS Titanium 1250 W/1650 W, because the Riing Duo RGB Fan is installed in the PSU, it makes it easy to achieve your ideal aesthetics without hassle. Toughpower iRGB PLUS Titanium Series comes with a fully modular design with Low-Profile Flat cables, 100% high-quality 105°C Japanese capacitors, and 80 PLUS Titanium Certified, and, last but not least, Smart Power Management Platform Support, which enables you to access information such as Efficiency/Wattage User Behavior, Energy Consumption Report, ECO report, Energy Saving, and more. The lineup also features SPM Security Protection, offering two major functions: Power failure Alert and Power Off Remote Control. First of all, by Power failure Alert, users can identify if your PSU has fan failure, over-temperature, or abnormal voltage through your mobile devices. Second, through Power Off Remote Control, you schedule when to turn off your computer without yourself physically being there to do it. This feature is particularly useful when you have to leave in the middle while downloading huge files, therefore, resulting in the best energy saving.
You can join the discussion on Thermaltake's new ranges of high wattage power supplies on the OC3D Forums.
