EVGA reveals their SuperNOVA GM series of SFX power supplies
EVGA has officially unveiled their new SuperNOVA GM series of SFX power supplies, which pack up to 650W of into the SFX-Standard form factor. This isn’t an SFX-L PSU, making it compatible with all SFX-oriented case designs.
This new range of power supplies boasts 80+ Gold efficiency levels, a fully modular design and a design that is built using 100% Japanese capacitors, delivering a pint-sized unit that is capable of powering most modern systems.
The SuperNova GM series ships with 450W, 550W and 650W variants, each of which offers a 7-year warranty, a lifetime that is sure to outlast most major system components. On top of this, EVGA promises tight voltage regulation features, promising to deliver voltages that are within 2% of their targets, ensuring rail stability and component safety.
Included with this PSU is everything that a user could need, from a power lead to a vast array of cables. EVGA is also supplying SuperNova GM series PSUs with an SFX to ATX adapter, which will allow this compact power supply to be used with full-sized cases if needed. EVGA lists their SuperNova GM series power supplies with the following features.
Features
– 100% Japanese Capacitors ensure long-term reliability
– 80 PLUS Gold certified, with 90% (115VAC) / 92% (220VAC~240VAC) efficiency or higher under typical loads
– Fully Modular to reduce clutter and improve airflow
– Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
– Double Ball Bearing fan for exceptional reliability and quiet operation
– SFX-Standard Form Factor packs large power into a small space for compatibility with mITX cases and compact gaming systems
– Auto ECO Mode to ensure silent operation under low to medium loads with no configuration necessary
– Active Power Factor Correction (PFC)
You can join the discussion on EVGA’s SuperNOVA GM series power supplies on the OC3D Forums.Â
