Corsair's "SHIFT" series PSUs are both absurd and amazing!
Accessing your PSU's cables has never been easier
Corsair's
Corsair has shifted the world of PSUs, and we are all for it
Thanks to @momomo_us on Twitter, we have gotten our first look at Corsair's RM1200x Shift power supply, a PSU that is unlike anything that we have seen before.
Corsair's new "Shift" series power supply has its power connectors coming out its side, directing them behind the motherboard tray of most PC cases. This allows for easy access to the RM1200x Shift's cables, making it much easier for PC builders to upgrade their systems and manage their PSU's cables.
According to @momomo_us, Corsair's new RM1200x Shift power supply will be Intel ATX 3.0 certified, and based on the provided images of the power supply, the PSU doesn't feature direct support for the 12VHPWR (12 Volt High Power/16-pin) power connector, which likely means that this PSU only supports 12VHPWR though the use of Corsair's 12VHPWR PSU adaptor (which may be supplied with this new PSU).
A game-changing PSU design
Corsair's RM1200x Shift power supply will make cable management a simple process when used with compatible PC cases. With this PSU design, cases must have clearance for the RM1200x Shift's modular cables, something that is not guaranteed.
With this PSU design, cable management is made easier, and the space at the bottom of PC cases could be utilised for something other than PSU cables. Perhaps this new PSU design could allow Corsair to experiment with bottom-mounted case fans, or other unorthodox new case designs. One things for sure, this unique PSU design opens up a lot of doors for Corsair, but only time will tell if PC builders are willing to purchase such an unusual PSU.
You can join the discussion on Corsair's angled "SHIFT" series power supplies on the OC3D Forums.
«Prev 1 Next»
11-01-2023, 19:22:51
AngryGoldfish
Hmmm this could be really interesting if more widely adopted.Quote
12-01-2023, 12:03:11
robert3892
Looks like this PSU will have to be mounted fan side down. I'll buy one as soon as it becomes available.Quote
12-01-2023, 12:10:56
Warchild
All my PSU have been mounted fan side down. Its the logical position given the amount of cases with dust filters below etc.
But I do wonder. With cases that may have limited space between side of the psu and the side case wall, once you plug the connectors in, you may be putting pressure on the connectors with stiff cables.
Could we end up with the connector fiasco of the 4000 series Nvidia cards, but from the other end?Quote
12-01-2023, 15:04:36
queeg
More suited to the dual chamber type cases where the psu fan cutout is on the side door in that usage this would be perfect i think its a great idea surprised its taken this long.Quote
15-01-2023, 21:06:04
Digikid
ALL power supplies should be mounted fan side down. That is the proper way and is why there are vents on the bottom of cases under the power supply.Quote
