Be Quiet! launches a 12VHPWR upgrade kit for their high-end PSUs
Be Quiet's PSUs can now be upgraded with 12VHPWR connectors
Published: 13th October 2022 | Source: Be Quiet |
Be Quiet's latest PSUs are now compatible with Nvidia's RTX 40 series GPUs
Be Quiet has just launched a new 600W 12WHPWR upgrade kit for its Dark Power 12, Straight Power 11, and Pure power 11 Power supplies, allowing their units to be fully compatible with Nvidia's new RTX 40 series graphics cards.
Be Quiet has rated their new 12VHPWR cables at 600W, and have confirmed that these cables will support an RTX 4090 graphics card when used with 850W+ power supplies, and support an RTX 4080 with a 750W+ power supply. Be Quiet's new adaptor solution is designed to act as a tidier alternative to the 4x PCIe 8-pin adaptors that ship with most RTX 4090 graphics cards, allowing Be Quiet users to create leaner PCs with less cable clutter.
What you need to know about be quiet's 12VHPWR adaptor cable
- 600W rated
- Handles all graphics cards requiring an 12VHPWR connector
- Requires 2 be quiet! 12-pin PCIe-Connectors on PSU side
- Elegant look with attractively black sleeve
- Usage as comfortable as a single cable
- Replaces bulky standard adapter solution
- 3-years manufacturer’s warranty
Be Quiet has stated that their new PSU power adaptors will be available at retailers soon, allowing users of their compatible power supplies to plug Nvidia's latest graphics cards into their systems without bulky 3rd party adaptors.
You can join the discussion on Be Quiet's 12VHPWR upgrade kit on the OC3D Forums.
