Razer enters the Streaming market with their Ripsaw HD capture card
Thanks to their Ripsaw’s use of HDMI 2.0, their device offers compatibility with a wide range of gaming products, from PC to consoles such as the PS4, Xbox One Nintendo Switch and basically any modern HDMI device. The box supports a wide range of resolutions, including 4K, 1440p, 1080p, 720p and 480p, which covers a wide spread of potential devices.Â
At launch, Razer will support Open Broadcaster Software (OBS), Mixers, Streamlabs, XSplit, Twitch and YouTube, acting as a simple plug and play solution to game streaming. This box connects to a user’s PC using USB 3.0 using a Type-C to Type-A cable.Â
 Â
Right now, Razer’s Ripsaw HD capture card is only available on the Razer web store for £179.99 in the UK, though the device will be available across a wider range of retailers as Q2 2019 progresses.Â
You can join the discussion on Razer’s Ripsaw HD capture card on the OC3D Forums.Â
