Google's Stadia controller finally works on PC
It only took about six months...
Published: 6th May 2020 | Source: Google - This Week on Stadia |
Now, around six months after Stadia's launch, Google has finally enabled support for wireless connectivity when using a Stadia gamepad with a PC, using WiFi to directly connect to the user's router. This functionality will be rolling out to Stadia users this week.
Some users have reported that this move has increased Stadia's compatibility with unsupported devices, allowing Stadia controller inputs to be sent to Stadia servers using WiFi while gamers utilise the browsers of unsupported hardware.
Below is what Google has to say about Stadia's wireless controller support on PC.
Wireless Stadia Controller support comes to laptops and desktops
Starting this week, you can now use the Stadia Controller to play wirelessly on your laptop and desktop. You no longer need to connect your Stadia Controller physically to your computer to play your favorite games. You’ll be able to link your Stadia Controller and Stadia.com through your Wi-Fi network and play without a USB-C cable connection.
You can join the discussion on Stadia Controllers finally working wirelessly on PC on the OC3D Forums.
