XFX's first custom RX 5500 series variant smiles for the camera
Is this XFX's RX 5500 THICC II?
Images of what appears to be AMD's first custom Radeon RX 5500 series graphics card have appeared online, revealing what could be XFX's THICC II model, which ships with a twin-fan cooler, a full-cover backplate and an 8-pin power input. The images in this article come via Videocardz.
Unlike most modern graphics cards, the XFX's apparent RX 5500 design features dual DVI-D outputs, a single HDMI connection and a DisplayPort 1.4 port. This is a rare configuration for a modern graphics card, though it reflects the reality that many low-end GPU users are still using older DVI monitors.
While this graphics card is likely to be a Radeon RX 5500 series graphics card, there is also the possibility that this is an AMD RX 5500 XT. The Radeon RX 5500 XT is a rumoured graphics card model which will feature more stream processors than AMD's already announced RX 5500. AMD's RX 5500 uses 22 GPU compute units, whereas AMD's Navi 14 silicon is rumoured to feature a total of 24 compute units.
Specifications for AMD
Reference Models
AMD Radeon
RX 5700 XT 50th
AMD Radeon
RX 5700 XT
AMD Radeon
RX 5700
AMD Radeon
RX 5500 (Desktop)
AMD Radeon
RX 5500M (Mobile)
Process Tech/ Architecture7nm Navi7nm Navi7nm Navi7nm Navi7nm Navi
Stream
Processors
25602560230414081408
Base
Clock
1680MHz1605MHz1465MHz--
Gaming Clock1830MHz1755MHz1625MHz1717MHz1448MHz
Boost
Clock
1980MHz1905MHz1725MHz1845MHz1645MHz
Memory8GB GDDR68GB GDDR68GB GDDR64/8GB GDDR64GB GDDR6
Memory
Bus
256-bit256-bit256-bit128-bit128-bit
Memory Clock14Gbps14Gbps14Gbps14Gbps14Gbps
Memory
Bandwidth
448GB/s448GB/s448GB/s224GB/s224GB/s
Cooler DesignBlower FanBlower FanBlower Fan--
UK Pricing (OCUK)£429.99£379.99£329--
US Pricing (MSRP)$449$399$349--
Given the low power design of AMD's RX 5500 series of graphics cards, it is likely that XFX will also release a smaller, ultra-compact variant the RX 5500, delivering end-user a graphics card design that's well suited to small form factor systems and OEM system builds.
At this time, all AMD has told us about Radeon RX 5500's consumer release is that custom models from ASRock, ASUS, Gigabyte, MSI, PowerColor, Sapphire and XFX are all due to release this quarter.
XFX's first custom RX 5500 series variant smiles for the camera Read more about XFX's first custom RX 5500 series graphics card on the OC3D Forums.
«Prev 1 Next»
