Specifications for AMD's Navi-based Radeon RX 5700XT Leak
Navi's clock speeds are incredible!
Published: 9th June 2019 | Source: Videocardz |
If you look at the chart below, you will notice that Navi's clock speeds are significantly higher than what is offered on Radeon's current-generation graphics cards, with Navi delivering higher base performance than the maximum boosts of all other listed graphics cards. This comes thanks to AMD's Navi architecture, as well as Radeon's use of 7nm manufacturing.
While the pure TFLOPS numbers of the RX 5700XT are lower than the RX Vega 56, it is worth remembering that AMD promises a huge boost in GPU IPC with Navi, which will deliver team Radeon with additional performance gains.
Below are the specifications of AMD's Radeon Navi RX 5700XT graphics card, as compared to AMD's existing graphics card lineup with similar Stream processor counts.
RX Vega 56 | RX 5700XT (Leaked) | RX 590 | RX 580 | RX 570 | |
Process Tech and Architecture | 14nm Vega | 7nm Navi | 12nm Polaris | 14nm Polaris | 14nm Polaris |
Stream Processors | 3584 | 2560 | 2304 | 2304 | 2048 |
Max FP32 Compute | 10.5 TFLOPS | 9.75 TFLOPS | 7,1 TFLOPS | 6.2 TFLOPS | 5.1 TFLOPS |
Base Clock | 1156MHz | 1605MHz | 1469MHz | 1257MHz | 1168MHz |
Gaming Clock | 1755MHz | - | - | - | |
Boost Clock | 1471MHz | 1905MHz | 1545MHz | 1340MHz | 1244MHz |
Memory | 8GB HBM2 | 8GB GDDR6 | 8GB GDDR5 | 8GB GDDR5 | 4/8GB GDDR5 |
(Image via Videocardz)
AMD is likely to officially reveal their first Navi series graphics cards tomorrow, as part of the company's Next Horizon Gaming event at E3 2019.
You can join the discussion on AMD's Navi-based Radeon RX 5700XT graphics card on the OC3D Forums.
